Oxygen Sensor "simulator"
Old Apr 19, 2010 | 01:46 PM
iROK24/7's Avatar
iROK24/7
Default Oxygen Sensor "simulator"
I noticed someone mention "Oxygen Sensor Simulator" in another thread. I've been having trouble passing emissions in MA because my Roush has headers and an off-road H pipe (no cats). I'd been planning to invest in a hi-flow catted H-pipe, but if the "simulator" will fool the emissions test by simulating a signal that the cats are working... THAT would be an even BETTER solution (cheaper AND doesn't alter my car's performance).
http://www.amazon.com/Oxygen-Sensor-.../dp/B001PCL02O
Does anyone know if would this device work for me?
Old Apr 19, 2010 | 02:21 PM
iROK24/7's Avatar
iROK24/7
Here's another (even cheaper) solution I just found in a Google search...
http://forums.evolutionm.net/evo-how...ouler-how.html
Old Apr 19, 2010 | 03:00 PM
hammeron's Avatar
hammeron
getting warmer
Old Apr 19, 2010 | 03:23 PM
VRFlip's Avatar
VRFlip
Originally Posted by hammeron
getting warmer
If you know how, why not help the guy out, instead of a cryptic response?
OP, I've seen the drilled out non-fouler method used a few times. No personal experience though.
Old Apr 19, 2010 | 03:47 PM
ejanderson05gt's Avatar
ejanderson05gt
Give this a shot.
http://www.paladinmicro.com/MustangMILEliminator.htm
Old Apr 19, 2010 | 03:59 PM
hammeron's Avatar
hammeron
good point and fair enough.
Originally Posted by ejanderson05gt
that is an excellent link, i'd like to hear what db157
thinks about it and whether it could work.
Old Apr 19, 2010 | 04:25 PM
NOLA26's Avatar
NOLA26
What kind of emissions test do they do? They have a few cities in Louisiana that do emissions testing but they do it by putting a sensor in your tail pipe and telling you to start your car, so no matter if you were getting a CEL or not if your actual emissions were over the limit you would fail. So some states just look at your dash to see if you have a CEL?
Old Apr 20, 2010 | 05:49 AM
iROK24/7's Avatar
iROK24/7
INteresting developments on this thread while I slept...LOL! I'm going to explore the ideas presented here & let you know my findings...
In MA the emissions test just plugs into the OBD port & checks that O2 & cats read "ready"... mine read "not ready". I believe there MUST be a way to "fake" the desired reading electronically. One of these simulators should work, however there was mention in the paladinmicro link that "newer cars" may be too sophisticated to be fooled by the device presented there.
Old Apr 20, 2010 | 06:22 AM
jahudso2's Avatar
jahudso2
The non-fouler trick might work, but I'm pretty sure the resistor won't work. I think the reason there are no "MIL Eliminators" for our cars, is because the control unit is too smart to be fooled by a simple resistor.
Old Apr 20, 2010 | 07:53 AM
iROK24/7's Avatar
iROK24/7
So what do you guys think of this email I got after inquiring about the simulator sold by a certain company (I blocked the name so as NOT to get them in trouble) - any techies want to take a stab at it? The get $69 for each unit... which seems a bit high!
Thanks for contacting XXX.
XXX simulator does work on your Mustang (if fitted with 4-wire post oxygen sensor) and cures all catalyst efficiency and oxygen sensor related error codes resulted by exhaust modifications (header or free flow cat back) or decatting thus you can retrieve the power lost due to check engine light illumination.
Dual exhaust with two post oxygen sensors requires 2 units.
Jb145700
Aug 21, 2022 06:37 AM
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
