Wheelhop?
#32
Maybe they were installed wrong? I would have to think that if you got NVH from that, they faced the offset the wrong way or something.
#36
yeah, like most things you can usualy make a triangle. In this cas it would be Price, Stiffness, and noise. You can pick 2 but sacrafice 1. There are exeptions to it, but the J&M IIRC are on the really cheap end.
#37
In regards to aftermarket LCAs and wheel hop... My concern is going into a ditch due to binding, and additional vibration resonated and magnified by a 1 piece drive shaft.
With both of those considerations in mind, what do the resident experts in this thread recommend for LCAs?
#38
I'd get the Gt500 LCA's. I've seen them a few places for about $130.
#39
#40
I have experimented a bit with modifying poly for less bind, and never noticed any additional NVH myself. Just so you know, that was on the '79 Malibu, which is a body-on-separate-frame design rather than a unibody so there is still a little more isolation (even after the body bushings were swapped out for poly as well).
Norm
