What should I replace the Shaker 500 with?
Installing an aftermarket radio in these cars is cake, just make sure you pick up the right mounts and adapters:
You can use this
http://www.crutchfield.com/p_127C2RF...nterface&ssi=0
or this one if you want to work a bit more but save $$$$$$$$$$
http://www.crutchfield.com/p_1207055...+harness&ssi=0
And this mount
http://www.bestbuy.com/site/Metra+-+...unt&cp=1&lp=15
You can use this
And this mount
Ahh... is $350 not realistic? I was thinking the Pioneer AVIC as that was only 259 off Amazon. I was not aware that cabling, mounts, adapters are sold separately.
Thanks for the warning on the 12v v 4v problem. However, the specs for Pioneer list pre-amp voltage at 2.2 Does that mean I would not need an amplifier for that particular model?
Anyone with the Pioneer AVIC wanna share their experience in installing it etc etc?
I did the install too and it wasn't that bad considering it was my 1st ever. I too wanted a cheap nav HU. However quickly relized how much i was going to have to spend if i didn't want to mount a big turd in my center console. I ended up scrappin the idea and went with a kenwood ddx512 which would be this years ddx514. It doesn't have all the fancies but works and looks really good. And the plus is you can get all the stuff for it as you have money such as nav,bluetooth,sat, and whatnot. http://www.sonicelectronix.com/item_...-DDX-514-.html
