Help please. Just installed 20 inch shelbys 295/35
Sorry to tell you this but 30mm is not enough offset. Unless you're into HotWheels cars tires that stick out look well .... I run 11" wheels and 315 tires and they don't stick out but have 45mm of offset.
i ordered those smae wheels for my car, bu tin 18" size and the 30 is the offset of the 10" wheels for the rear, teh fronts are 40. Tehy damn well better fit, i ordered the 295/18-45 which is what the s197 size actualy is in 18". I hav ebene waiting for a month now for my nt05's to show up. If that is not the right offset and i cant return the wheels now thanks to not being able to fit the tires, I will be major pissed. That seller says that these are the right offset for the 10's and they had better be.
After lookign at your auction, i don't htink those are the right wheels for your car, did you link the right auction? Teh specs say that the bolt pattern is different from what a stang shoudl use. my 18's are 5x4.5, those say they are 5 x 4.75. Not sure if that matters, i still be a adj panhard will fix you up.
these are the ones I ordered:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
http://cgi.ebay.com/ebaymotors/ws/eB...d=140405432517
that tells you the specs of the rear rims. 30 offset, i will look into the panard bar also. Looks like its def going to push it with the room in the wheel well making it fit and not hitting. And for the springs i was thinkin pro-kit or even a less lower drop spring? Thanks
EDIT: Ok now maybe i am all mad for nothing, apperently a lot of shelby 10" rears for the stang use 30mm offset:
http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
OP, again pics of the rears befoer i go bat shat on the ebay seller.
