N/A mods
Old Jun 2, 2010 | 09:19 PM
X3xMONGOOSEx3X's Avatar
X3xMONGOOSEx3X
It's not hard to get 450+RWHP out of a Whipple S/C just depends on which one you chose and which setup will pass your state inspection.
Whipple HO
http://www.youtube.com/watch?v=7fSUE...eature=related
Last I knew Kenne Bell were trying to or have for the most part engineered the whine out of their S/C's. It's a damn shame.
http://www.youtube.com/watch?v=9FV-EzEsd1U
Old Jun 2, 2010 | 09:29 PM
Alec's Avatar
Alec
WHAT, WHY?!?!?
I honestly think that there is no better sound in the world then a Terminator at WOT
Old Jun 3, 2010 | 07:35 AM
Nuke's Avatar
Nuke
What's your budget? To keep it a good street car you can still do quite a few things beyond the CAI & tune w/o going FI and keeping the cats.
Nitrous
Cams
LT's w/catted X or H
UDP's
CMDP's
Aluminum DS
Electric water pump
Lose weight (rear seat delete, lighter wheels, no spare, etc)
Gears
Of course, after adding RWHP you'll definitely need to do some suspension work and new rubber to hook-up.
Old Jun 3, 2010 | 08:51 AM
UpTo11's Avatar
UpTo11
Engine/Induction
-Eagle Stroker Kit
-Ford Racing Intake Manifold
-CNC Ported Heads
-FRPP Hot Rods
-Ford Racing 62mm Billet Throttle Body
-Steeda Cold Air Intake Kit
-Steeda Charge Motion Control Plates
-Roush Underdrive Pulleys
Drivetrain
-Steeda One Piece Aluminum Driveshaft
-Moser 8.8in 31 Spline Axles
-Eaton 8.8 in 31 LSD
-FRPP 4:10 Gears
Transmission
-TCI Streetfighter Torque Converter
-TCI Streetfighter Ratchet Shifter
Exhaust
-Kooks Longtube Headers
-Electronic Exhaust Cutouts
-Kooks Catted X Pipe
Weight
-Battery Relocation
Fuel
-BBK High Flow Aluminum Fuel Rails
-Ford Racing Ev6 80lb Fuel Injectors
Cooling
-Mishimoto Performance Aluminum Mustang Radiator
Brakes
-Brembo GT Front Big Brake Kit - Slotted Rotors
Suspension
-Tokico D-Spec Adjustable Strut & Shock Kit
-Eibach Pro Kit Spring Set
-J&M Mustang 4-Bolt Caster Camber Plates
-Eibach Mustang Anti-Roll Kit
-Steeda Chromoly Steel Lower Control Arms
-Black Mustang Strut Tower Brace
-J&M Mustang Adjustable Panhard Rod
Wheels
-18x10 Rear, 18x9 Front
-Nitto NT555's (255/45-18 Front) (275/40-18 Rear)
Old Jun 3, 2010 | 08:59 AM
UpTo11's Avatar
UpTo11
Just noticed half those mods aren't legal in your state...whatever. Move out of CA?
Old Jun 3, 2010 | 04:24 PM
Quick_SilverGT-06's Avatar
Quick_SilverGT-06
haha no thanks....and the money is none but were looking for a list of things to do when we do get cash. We were looking at either the Whipple supercharger Twin screw or STS turbo. maybe Heads with small enough cam to pass smog. Coil overs bigger wheels and tires. smog legal shorty headers. either Magnapacks exhaust or stingers
Old Jun 3, 2010 | 04:47 PM
DRock's Avatar
DRock
Im pretty sure that the STS turbo kit wont pass. Heads would be hard to tell if they were factory of not. And if your geting a small cam at that point you dont need heads. Im getting long tubes and am goin to try and pass smog(im keeping the kitties), but then agian i gots friends in the right places. Find a NICE shop that dont know what they are looking at.
Old Jun 3, 2010 | 04:55 PM
X3xMONGOOSEx3X
Doesn't CA have a special vehicle law or something that allows you to bypass inspection. I thought I heard of something like that but I'm sure it costs lots of money. I think that's how Leno got his Ariel Atom road legal.
Old Jun 3, 2010 | 05:34 PM
breathegood's Avatar
breathegood
How willing are you to flirt with what will and won't pass emissions?
To be completely and totally compliant with CARB, your N/A options are CAI with CARB EO (Steeda qualifies), JBA shorty headers are the only headers with CARB EO, UDP's, and an Al driveshaft. Technically, I think even a flash of the computer is a no no to be totally compliant, but we are picking at nits on that point.
Quit thinking about heads unless you are going to build the motor or plan to run it at higher rpm all the time. The torque loss on the low end isn't worth the minimal gain up top on stock displacement. Especially given the cost.
STS is junk (ask me how I know) and does not have a CARB EO (yet).
Cams are a great idea, but think hard about what you ultimately want. A great N/A cam isn't going to be ideal if you one day decide to go F/I, but a F/I cam will not allow you to get the most out of a N/A motor. If F/I is your ultimate goal, pick the right cam from the begining.
IMO, a positive displacement super charger is the best option for a daily driver. The low end grunt is what makes driving fun without always having the engine wound up. Whipple, Kenne Bell, Roush, Saleen, Edlebrock are all excellent options and I believe are all CARB legal when installed by and tuned by an authorized dealer.
Old Jun 3, 2010 | 05:39 PM
Thrashard340's Avatar
Thrashard340
Passing visual is only half the battle. The other half is beating tailpipe emissions. High flow heads may allow you to get more air/fuel mixture in, but it is also almost certainly going to increase exhaust emissions as well. Some of you guys are throwing suggestions out there that won't pass CA smog. But maybe the the OP should clarify to what degree of smog friendliness he wants his parts to be. CA is probably one of the top 3 toughest states to pass smog. In most areas, it requires dyno-load testing.
