A/C
Old Jul 18, 2010 | 11:50 PM
ZERO4572003's Avatar
ZERO4572003
Default A/C
How do you recharge your a/c on a 06 mustang gt ??
Old Jul 19, 2010 | 01:13 AM
siggyfreud's Avatar
siggyfreud
Get a recharge kit and follow its instructions. Get one with a pressure gauge. It's rather easy. Canister plugs into low pressure side while the AC is on Max and you hold the canister upside down until the pressure gauge reads within range.
Old Jul 19, 2010 | 08:41 AM
doctorstrobe's Avatar
doctorstrobe
The port where you inject the new coolant is on the driver side, right up near the firewall, down below the brake fluid...
There's a small black plastic cap covering the fitting that you unscrew.
Old Jul 19, 2010 | 05:25 PM
Root66's Avatar
Root66
Uhhh, not a good idea, inverting the can introduces liguid refrigerant into the system and this can hydro-lock (slug) the compressor. The tapped end should always be up, this allows only gas into the system.
Old Jul 19, 2010 | 06:39 PM
allinon72's Avatar
allinon72
Every recharge kit I've ever had tells you to invert the can.
vargas
Jun 17, 2017 12:17 PM
69Volunteer
Sep 30, 2015 10:39 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
HIS S-197
Aug 10, 2015 05:47 PM
