Two odd noises...need help!!
Old Aug 2, 2010 | 02:23 PM
CWyler's Avatar
CWyler
0hsix, I have the same problem...apparently... I don't notice it, but everyone who rides in my car says it sounds like what you are describing. Its not the tires, I went from the Stockers to Nitto 555's and the sound was still there. I think it may be gear whine but I could be wrong
Old Aug 2, 2010 | 11:13 PM
datsyuk's Avatar
datsyuk
Is your tranny auto or manual? I had a completely stock 06 and the transmission whined, Ford said there was a problem but my dealer took it back and tried to give it to me which we did not accept it. Called Ford and found it the truth, got real angry and gave them the car back (lots of ongoing problems with them led to this) so we never actually found out was wrong with the tranny specifically, he knew there was something abnormal about it though.
Old Aug 3, 2010 | 12:54 AM
Ohsixgeetee's Avatar
Ohsixgeetee
It's a manual, this started around the 40k mark.
Old Aug 3, 2010 | 08:58 AM
CWyler's Avatar
CWyler
Mine whines as an auto...as you said its coming from the rear, at least mine is.
Old Aug 3, 2010 | 09:29 AM
BigDinTexas's Avatar
BigDinTexas
Originally Posted by Ohsixgeetee
So in the past month or so I've noticed two new noises.
1) a sound almost like a wobbling that began to occur after tires were rotated at dealership. Possible balance problem?
2) A sound while driving, only audible from inside the car as far as I can tell, that sounds almost like a CD spinning on a cd player. It increases with speed and is really starting to worry me.
Any help with a diagnosis would be appreciated before I go in and get taken by the dealership.
If it's not mechanical, I wonder if that sound could be coming from your stereo since you said it increases with speed... I had a bad headunit once that would cause a "whine" to come from the rear speakers as I drove... You could hear the car RPM's increase through the speakers...
Don
Old Aug 3, 2010 | 10:05 AM
Roy_R's Avatar
Roy_R
Turn up the radio...this a Mustang, they make noise, alternatively give it to me and buy a Prius!!!
Old Aug 3, 2010 | 10:43 AM
Ohsixgeetee
Don
I had considered this, did it still whine with the radio off? Also did it really increase with rpm or with speed?
Oh and to the prius comment, I can deal with rattles and buzzes from the cheap plastic dashboard, got a set of stingers to drown them out =]. But I like to pinpoint the different sounds before I write them off as nothing.
Old Aug 3, 2010 | 10:52 AM
BigDinTexas
In the instance for me, yes, the noise did persist, even when the radio was turned off, almost like a bad ground, which it could have been too... It would increase with RPM.
Don
Old Aug 3, 2010 | 11:05 AM
Ohsixgeetee
Don
Thanks, this seems like the most reasonable cause so far although mine is dependent on speed rather than rpm. How did you fix it? Or did you just leave it be?
Old Aug 3, 2010 | 11:28 AM
HypromanGT's Avatar
HypromanGT
I'm with you. I like to know what has happened to cause a change. I wonder how many of these guys in the "don't worry about it; turn up your radio" crowd have ever been stranded on the side of the road because they didn't listen to their vehicles telling them that something really bad was going to happen. To each their own, I guess...
On a somewhat more topic-related note, I get my tires rotated roughly every 15k and I usually notice some cyclical sounds either just before or just after the rotation. I figured it was just tire wear (oh, and I turned the radio up :-P)
Nurdyguy
Jan 20, 2025 04:38 PM
drfister
May 3, 2018 10:38 PM
Urambo Tauro
Oil and Oil Related Topics
Dec 11, 2017 07:16 AM
mustangchef
Sep 4, 2015 08:08 PM
Nurdyguy
Aug 21, 2015 10:23 PM
