2008 Mustang GT Reference Pic Needed
Can someone with a 2008 GT with OEM HID headlamps take a picture of the relays for me and post it? These should be mounted on the passenger's side shock tower next to the fuse block.
Also, I need a good shot of the fuse block - I need to see what amp fuses are in the slots immediately below the center bolt that holds the fuse block down.
Thanks!
Thanks!
Need 2008 factory HID headlamp info from Kenthicken
Kenthicken,
I'm also attempting to install OEM HID headlights into a 2008 Mustang that was not originally equipped with them. I have the headlights and a new factory HID harness. I have the same questions and concerns you expressed concerning the wiring harness issues. The 2008 fuse boxes have 2 fuses dedicated to the HID headlights. Have you been able to complete your HID swap and if so did the factory HID harness need to be modified to work on a 2008 (as opposed to a 2005-07) as discussed in the SilverHorse Racing tech article or was it a bolt in swap? You can contact me by email at jcaruso100@aol.com. Any information will be greatly appreciated.
Jskeezy84
09-08-2015 01:40 AM
