Shock/spring help
Old Sep 10, 2010 | 07:42 AM
Alec's Avatar
Alec
Default Shock/spring help
The last day or so my right rear has been squeaking and last night I came out and the right rear side was noticeably lower, or slanted, than it normally is. It's definitely drive-able, but isn't right. Any ideas what this would be? Springs? Shocks? I'm thinking it's the shocks but don't know much about suspension
Old Sep 10, 2010 | 08:10 AM
2005Redfire6's Avatar
2005Redfire6
You have stock suspension right? Maybe somehow your spring isn't seated right on that side, did you hit something by any chance? And how many miles do you have? Shocks tends to squeal when blown.
Old Sep 10, 2010 | 08:28 AM
Alec's Avatar
Alec
Stock suspension with 59k. I haven't hit anything but ill have to pop the tire off and take a look later
Old Sep 10, 2010 | 09:16 AM
2005Redfire6
I'd bank on a blow shock, my buddies squealed when it was blown. Does it ride any different or does it seem to bounce around in the back?
Old Sep 10, 2010 | 10:16 AM
Alec's Avatar
Alec
It never rode great but I haven't noticed anything recently. The stock suspension sucks in my opinion so its hard to tell. How hard is it to install a set of shocks?
Old Sep 10, 2010 | 11:58 AM
Norm Peterson's Avatar
Norm Peterson
Shocks do not determine the ride height, so I'd first suspect the RR spring. A bad shock can help hasten the end of a spring's life, but I doubt that this would be an overnight thing.
Rear shocks are really simple to replace, and rear springs also look pretty easy.
Replacing the front struts and springs is a more involved task, and should be followed up at the very least with an alignment check. It's even a good idea to measure the existing alignment before taking things apart, as you'll then have an idea how much things changed. It's really not that difficult to DIY, so no need to pay twice (or maybe even once) for this.
Norm
Old Sep 10, 2010 | 12:09 PM
Alec's Avatar
Alec
Norm
It wouldn't be the worst thing if it was the spring, I've wanted to lower it a little. Not necessarily now, but I guess that's how it goes. I notice most of the "squeaking" taking off from a dead stop. Is there anything in particular I should look for to determine the problem?
Old Sep 10, 2010 | 12:59 PM
Cal26Stang's Avatar
Cal26Stang
sounds like its time for some D-Specs
Old Sep 10, 2010 | 01:03 PM
Alec's Avatar
Alec
Ha yeah that's the way I look at it. If it's a problem and I have to replace something, at least it will be an upgrade. It's still squeaking today but doesn't look at bad as it did last night hmmm
Old Sep 10, 2010 | 02:36 PM
Cal26Stang's Avatar
Cal26Stang
thats always my excuse to upgrade...oh uh yeah its broke, so....yeah i guess nows the time to show you these new ones...lol i use that alot
StangingAround
May 15, 2014 06:38 PM
ThaiCobra
Jun 1, 2012 07:48 AM
Pubydingus
24
Aug 9, 2011 01:41 AM
trz06
Nov 4, 2010 08:20 PM
Xyron
Jul 29, 2010 07:34 AM
