Whipple which one?
You were at 100% duty cycle on your pump with a BAP that low in HP?!? Seems pretty crazy.
http://site.brenspeed.com/instructions/fuelpumptech.pdf
I'm pretty well over that and havent had a problem with mine, and I dont even run mine all the way up.
OIC. We were talkiing about him getting the BAP and you said to go with the GT500s it sounded like you had a problem with the BAP idea. Definatly, cant go with just a stock pump, but a stock pump with the BAP module for like $230 can keep up to a fairly high level of modification. Unless hes planning on putting more then 10Psi to the motor, he should be fine with a BAP.
Hi again
The kit is the HO intercooled version 550hp and the kit hasnt been tampered with so all pullies are the same.
So I couldnt run with just the stock pump for a short period till I bought a BAP or GT500 pump?
Great ok thanks for your reply new pump it is.
I purchase a Diablo tuner for my 05 recently and from reading the other posts the Diablo isnt really for supercharger tunes and I would need a Dyno tune instead. As I have just purchased the Diablo should I return it unused and put $300 towards the new fuel pump as it doesnt sound like I am going to get much use out of the Diablo.
Any thoughts please ?
Thanks
stu
Thanks
stu
It depends, how are you planning on getting it tuned? One tuner is just as good as the other, there just a device for loading and unloading tunes to the computer. You want to figure out who is gonna tune it, then see what device they can use.
http://www.diablosport.com/index.php...display&pid=32
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
01roush33
May 26, 2006 09:32 PM
