I'm Stumped
that is the code you get when the gas cap is left off/loose
clear the code and keep driving. if the code comes back I'd worry about it. The fuel system basically does a pressure test when you start the car.
if the test doesn't pass, you get the Evap Leak code
The EVAP is the gas cap if im not mistaken, my last car (2006 GT) had a dried out gasket and sometimes would cause this randomly. However i never check the code. I simply put a little Petroleum Jelly on the seal and it never came back. If anyone knows for sure what the code is i would be interested to hear it but i it sounds like you need the extremly over priced gas cap seal or a $3 can of Vasoline.
The gas cap seal is actually a red split O ring and it will slip off the cap. Rather than buy a new gas cap, you could try a standard black O ring in its place. Typically std. O rings are made from Buna N (Nitrile) rubber, which is good material for use in gasoline service.
If Autozone is free to plug in, then I will go there for now on for any thrwon codes.
Yeah, they do it for free. Usually they have a sign up but you can just ask them.
CMcNam
10-30-2022 11:40 PM
ShaneB26154
35
03-04-2021 04:05 AM
stangin1996gt
09-21-2015 11:01 AM
