Old Oct 27, 2015, 10:50 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Passenger side cabin leak FIXED!!!
Old Oct 26, 2010 | 08:38 PM
Lifter583's Avatar
Lifter583
Originally Posted by siggyfreud
However, it takes less than that to begin impairing brain function and put the driver, and other drivers on the road at risk. Anything above 100ppm can be hazardous to your health. I think they (Ford) wanted to err on the side of caution. Over time, the Carbon Monoxide could build up resulting in much greater density than 100-150. Otherwise, you'd never be able to off yourself off your own exhaust fumes.
Side note: A car puts out 100-200ppm at the end of the exhaust. Should there be an exhaust leak, the PPM is MUCH higher. Like 7000 ppm.
You do present a good point... and it is better to be safe...the concentration could build up with no air flow to dilute it...but I believe that size of leak will cause problems no matter what...
Old Oct 26, 2010 | 11:52 PM
Art161's Avatar
Art161
A number of years ago my father had a series of minor accidents over a short period of time. The cause was determined to be carbon monoxide leaking into the passenger compartment.
Old Oct 27, 2010 | 02:55 PM
siggyfreud's Avatar
siggyfreud
A good story/warning for all of us to consider.
It's the catalytic converter that takes that 7000ppm and brings it down to 100-200ppm. Any leak before that portion of the exhaust will be MUCH denser in Carbon Monoxide than from anywhere after.
Old Oct 27, 2010 | 03:36 PM
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by Lifter583
It takes a dose of 800 ppm of Carbon Monoxide with an exposure time of 45 mins to be lethal...now that would be one hell of an exhaust leak!! Considering the entire exhaust output has about 100-150 ppm... I will take my chances...but thats just me...
You gotta love Wikipedia....
Old Mar 10, 2012 | 03:21 PM
Dale House's Avatar
Dale House
Smile
bm2088hp, THANK YOU!! I have had the water leak for a week now and it has been raining hard in Texas. I went and washed my baby today and had about 2 gallons of water rolling around on my passenger side. I was going nuts!! I just used your fix and it is fixed! Thank you so much!!
Old Mar 13, 2012 | 09:57 AM
Crobattt's Avatar
Crobattt
you guys didn't know this lol?
Old Mar 13, 2012 | 07:29 PM
Menace's Avatar
Menace
I went to check on this... the only thing I could find on the passenger side (didn't look on the driver's side) is a small oval shaped grommet. I removed it and directly behind it was foam... is this the spot or am I missing something?
Old Jun 15, 2013 | 08:50 AM
rooneyeb's Avatar
rooneyeb
Default Thanks!
That was easy... I saw the tub around the filter full of water but couldn't find a drain- the photos were perfect.
I was going to pull the small siphon from inside the rubber gasket, but I left it in for now and will keep an eye on it.
This was a good excuse to replace the cabin air filter too I guess...
Old Jun 23, 2013 | 07:11 PM
robs's Avatar
robs
Why would there be carbon monoxide in the engine bay??? Someone forget to bolt on the headers?
Old Jun 26, 2013 | 05:40 PM
JDBullitt's Avatar
JDBullitt
Thanks for posting this, I've had my car 8 yrs and never had this problem until now, was looking thru posts to see what the fix is, thanks again!
