Old Oct 27, 2015, 10:50 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Passenger side cabin leak FIXED!!!
Old Nov 11, 2018 | 07:34 AM
  #31
merendac's Avatar
merendac
Default Thanks
Originally Posted by bm2088hp
A few days ago we had a really bad rain storm. The next day when I took the car out, water started gushing out from under the glove compartment box. I'd say that about a cup of water came out and got my floor mat as well as the carpeting under it wet. A little after, I washed my car to see if the same problem would happen and once again it did. After looking around and removing the bottom of the windshield plastic drain covers, I saw about a gallon of water in the drain. The drain was obviously clogged up and all that water was coming in though the cabin air filter.
There are 2 drain holes that can get clogged up, one on the driver said and one on the passenger side. Now I know that getting to them and cleaning them out is super quick and easy. Below are a few pics showing you how to get to them so that you don't run into the same leak problem like I did. Definitely check them once in a while to make sure that leaves or other things don't clog them up.
Where the leak occurred:
Passenger side drain hole: It is hard to see where it is exactly but it is a small black rubber piece about 2" in width all the way in the back.
Driver side drain hole: This one is much easier to see and get to.
Thanks for the Post. It saved me a lot of time and if I couldn't have figured it out it saved me a lot of money
SXGT
Oct 17, 2012 06:29 PM
mustangkid_90
Jul 10, 2012 07:40 PM
sarlo
Aug 20, 2011 09:35 AM
056er
Aug 7, 2010 04:39 PM
aircare84
Apr 6, 2008 09:45 PM
