Knock sensor
Old Nov 4, 2010 | 05:09 PM
  #21
George Zimmer's Avatar
George Zimmer
Banned
Originally Posted by Riptide
I get blown any time I want. One of the perks of being married to a nymphomaniac.
Serial though. Picked up a used KB in September. As far as a problem I have none as far as I know. But people say it's good to datalog the car after you supercharge it. Even if KB says their tune is perfect no matter what.
I understand your suggestion sir. I was hoping I could find the answer to my question of which parameters need the checkbox without having to screw around with it like that.
If I do find a problem KB will need to write corrections into the tune remotely and then send me a new file.
You almost make me jealous. Actually....you are making me jealous. Have you ran the car with the new setup?
Old Nov 4, 2010 | 05:17 PM
  #22
siggyfreud's Avatar
siggyfreud
Sorry, I didn't mean to write it like you weren't understanding what I was getting at. I was just reiterating that it may be the only option you have unless someone with more experience chimes in.
Old Nov 4, 2010 | 05:23 PM
  #23
Riptide's Avatar
Riptide
hehe thanks man yah she's great. Doesn't even whine or bitch at me when I spend time working on the car. Can't complain about a thing.
Run the car WOT probably 12+ times now since the install including a 4th gear pull on the interstate. Pulls much harder now. No signs of any problems the car seems to run good. But you can have knock and not know it. Trying to be proactive about this stuff. The stock motor isn't gonna last forever but it may go longer if I keep an eye on it.
Old Nov 4, 2010 | 05:25 PM
  #24
George Zimmer
Banned
Do you think you can run 12's now if you DA correct?
Old Nov 4, 2010 | 05:36 PM
  #25
Riptide's Avatar
Riptide
It should run 12s without any DA correction.. Even up here in 6000' air. Assuming I don't blow the tires off or generally drive retarded like.
Mid to low 12s is my eventual goal.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
TfcCDR
Sep 14, 2015 12:08 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
