Got my LT's...now a dumb question
#32
I’ll be installing Pypes LT’s in the near future. I’ve been going through a lot of related posts and have some questions.
I’m currently in FL so I don’t have to have cats until I go back to TX. At that point can I clamp/weld my factory cats into the Pypes O/R X?
Until the cats are installed I still need the O2 extenders, correct? Or cap them off and update tune to O2 off?
I see a lot of back & forth on Percy gaskets and Stage 8 bolts. Are they worth the extra $$?
Any other key info I’m missing?
Thanks.
Thanks.
#34
Thanks.
Thanks.
#36
Thanks.
Thanks.
2. I did need O2 extenders. Some people will swear you don't. It was $40 and I didn't have to hassle with the bull****. Your choice. Front only though.
3. I put my old rear O2's into the H pipe to plug the holes. Simple
4. As far as gaskets and bolts, I re-used the factory gaskets (zero leaks btw) since they were metal and the motor only had maybe 4,000 miles if that. The LT's came with new bolts. I used a 1/2 mix of factory studs and the bolts to re-install. The pictures above should show why. The studs were just freaking easier to use.
As far as tuning, yes you will absolutely need tuning. Cats or not. My car ran like crap for 1 month until I changed tuners. BBR rocks. If you delete the cats, make sure the tuner knows and turns off the rear O2's or your car will pop a CEL and run rich
#37
Ok, here’s what I’m going with...
Roush axle back (already installed)
Hot Rod cams (ordering w/ the headers)
Pypes LT’s & O/R X
O2 extenders for the front sensors
O2 tuned to ‘off’ on the rear sensors to avoid a CEL
Factory gaskets
Use of both factory studs & supplied bolts
Updated Bama Tune
Once back in TX I’ll deal with having the factory cats welded in. Per Pypes, I’ll need their CVM10K cat kit. Per Bama, reusing the stock cats is best because of high flow cats not filtering out enough contaminants and the cars having issues with passing emissions.
Did I miss anything? And thanks for all the replies/PM’s.
Pypes LT’s & O/R X
Factory gaskets
Updated Bama Tune
#38
sounds good. I don't know your mileage, but you might want to pick up new gaskets just in case and not re-use.
compare the price of OEM new vs. the price of good aftermarket ones. should be a nice gain in power. I'm hoping to install some FRPP Hot Rods myself in a few months along with a centri blower
#39
Although...
I did see these bolts at Jegs. They're not locking like the ARP's but they may make the install easer. Anyone have any experience with these?
JEGS Metric Header Bolt Kit
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
