Octanes and tunes.
Old Dec 19, 2010 | 06:47 AM
MustangFirstCar's Avatar
MustangFirstCar
Can anyone tell me the most fuel in-efficient way to drive? I got lots of town, and AC/Heat on, but are there things you can do to decrease your mpg?
Old Dec 19, 2010 | 07:35 AM
Nuke's Avatar
Nuke
You don't want to cause engine ping. The lighter the load, the less likely it'll ping/knock. Mixing different octanes is acceptable. 1/2 tanks of 87 and 93 will yield an equivalent 90.
Old Dec 19, 2010 | 07:40 AM
MustangFirstCar
So by what everyone is telling me, I really should just siphon the gas out. Driving with 87 seems like a bad idea. Would a shop be able to drain the gas?
Old Dec 19, 2010 | 07:50 AM
Nuke's Avatar
Nuke
Our fuel tank design makes it difficult to put a siphon hose thru the filler tube but a shop could probably do it. But I think you would be fine for a bit just taking it easy and listening for ping/knock. Even if you refill with 93 at 3/4 tank you'll have close to 89 (~88.5).
You could always pull some timing with the tuner.
Old Dec 19, 2010 | 07:55 AM
baddog671's Avatar
baddog671
Don't our cars have an anti-siphon mechanism in the fillerhose?
How low was the tank when she filled it? If it was like half tank of 89, and she put 87 in it, then you're only like 1 point off. Just saying, it's probably not as bad as you think..
Old Dec 19, 2010 | 07:57 AM
MarkMan's Avatar
MarkMan
I think I would drive it until you have 1/2 tank and fill up with 93 octane. Just just keep the rpm's down as much as possible and accelerate slowly. Listen for the ping and if you hear it do something different. Not a huge deal!
Old Dec 19, 2010 | 09:50 AM
Vader GT's Avatar
Vader GT
Originally Posted by BruceH
Do you have an 87 octane tune? You could put your stock intake and tune back on. You could also drive like a grandpa with your current set up. If you hear a can of marbles rattling get off the throttle. Whatever you do don't put octane booster in, it will foul your plugs.
If you are still concerned do a google on toulene, octane, pump gas. You will find the amount of toulene needed to bring your octane up.
+1, just baby it & you will be fine. DO NOT put octane booster like stated above.
Old Dec 19, 2010 | 02:08 PM
MustangFirstCar
No, no. You misunderstand. I just tuned my car, and it has an 89 tune. But I have almost a tank of 87.
Old Dec 19, 2010 | 02:33 PM
ski's Avatar
ski
If you have a handheld tuner, then retard the timing 2 degrees.
Old Dec 19, 2010 | 03:50 PM
baddog671's Avatar
baddog671
I didn't misunderstand, you misunderstood my statement.
If you had 89 in the tank and your mom put 87 in the tank, unless you were running on fumes, there was still some 89 in the tank which would have mixed with the 87 and raised the octane level... Your probably fine to run it.
Just do like everyone has said, run a few gallons out of it and put some high-test in it to get the octane rating back up.
