Rear diff leaking from drive shaft input?
Old Jan 6, 2011 | 06:53 PM
Bmr4life's Avatar
Bmr4life
Default Rear diff leaking from drive shaft input?
I've been noticing a small puddle in the garage every now and then. I redid my diff fluid a few months ago. The dripping is definitely not coming from the gasket, I can follow the stains down from the input shaft.
So what do you think is wrong?
Old Jan 6, 2011 | 07:02 PM
Roy_R's Avatar
Roy_R
I think you may have a leak....
Old Jan 6, 2011 | 07:05 PM
Bmr4life's Avatar
Bmr4life
Yeah, but what would cause it to leak from there and how do I fix it.
Old Jan 6, 2011 | 07:42 PM
howarmat's Avatar
howarmat
s197 Junkie
pinion seal...i need to replace mine too. Mine is doing the same thing
Old Jan 6, 2011 | 07:43 PM
Bmr4life's Avatar
Bmr4life
So is that normal? I'm at 65k miles.
Old Jan 6, 2011 | 07:54 PM
howarmat's Avatar
howarmat
s197 Junkie
lol, well i wouldnt say its normal. but its relatively easy to get replaced by you or cheap if you take it to a shop. Its cold, snowy and such here i will probably just take it to a shop and it should take 1 hour or so to do the work. the seal is $10 or so. Im out $100 max vs spending 2-3 hours of my time in the cold on my back doing it
Old Jan 6, 2011 | 08:09 PM
simmster23's Avatar
simmster23
i had the same problem with my car at about 70,000 miles.. replaced the pinion seal and the leak went away
Old Jan 6, 2011 | 08:39 PM
Bmr4life's Avatar
Bmr4life
Cool. Thanks. I'm thinking this may be one I just pay a shop to do. Don't feel like being under the car again for a while after the LT install.
djbigskrilla
Sep 20, 2022 01:04 AM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
91StangOwner
Aug 20, 2015 11:34 PM
kevans79@yahoo.com
Aug 18, 2015 09:01 PM
Boostaddict
Lethal Performance
Aug 13, 2015 01:57 PM
