HID wiring options...
I decided to give DDM's basic 35w low beam HID kit a try. When I got it, I didn't receive any type of relay harness or anything...each bulb simply has a ballast and taps into the stock plug harness. From what I've read this is normal, but I'm worried about all that voltage needed to fire HIDs coming from the two tiny wires of the stock bulb harness.
I'm I nuts here or should I get a relay harness?
I'd put in a relay harness. I bought a Hi/low setup off of ebay and it came with a relay harness. You want to draw as little current threw the headlight switch as possible. Overheating the factory harness is asking for trouble.
well i donno bout the low kit but the hi/low kit comes with a wiring harness and works great with it.
we're also running an 07 civic with just a low kit and thats just using the factory wiring, havnt had any problems yet
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
