REMOVE THE ROCKER PANEL MOULDING
Old Aug 23, 2005 | 06:06 PM
jpepping's Avatar
jpepping
Default RE: REMOVE THE ROCKER PANEL MOULDING
ORIGINAL: Professor Wizard
I've done THAT..
It is EASY...
You just press rearward on the front bottom center of the seat .. push back and lift... comes right out!
Does it give you access to the trunk area, to run wires???? Seems pretty easy based on your description. Does the whole seat come out or just the seatback???
Thanks
Jim
[IMG]local://upfiles/14828/919B3D60EC644B4FBB15F003604523F3.jpg[/IMG]
Old Aug 23, 2005 | 07:00 PM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
The Bottom "pops" out...
The Rear section has a couple of bolts and then you lift and pull it out, but you won't need to.
On the far left and far right there are easy access holes along the wheel well. Put a light in the trunk and look from the seat side.. or the other way around and you will see them real easy. That is how/where I ran the wire for my power to my Chaser Tail Kit.
With the seat out, you can route the wires under and behind the rear side panels very easily without removing them.
Old Aug 23, 2005 | 09:00 PM
nbk13nw's Avatar
nbk13nw
It will not allow a PDF to be uploaded or attach it to an email or PM. Send me your email address if you want them.
Old Aug 24, 2005 | 02:08 PM
jpepping's Avatar
jpepping
I've done THAT..
It is EASY...
Cool, thanks for the info.. I think the XM antenna would be better on the trunk.
Jim
Old Aug 24, 2005 | 02:21 PM
nbk13nw's Avatar
nbk13nw
ORIGINAL: jpepping
Great, thanks.. hey where did you get the DVD service manual??? It sounds like that would be a handy thing to have.
Jim
Hey Jim,
You can pick one up on Ebay for under $40.00. There are several versions out there, be sure to select the 2005 Mustang. Also, the info is time stamped for the application to work properly. If you get an error saying that the info is out dated, then just set you date back in Windows until you finsih, then set it back. No issues, no big problems either. A great tool to have at your disposal.
jwog666
Dec 27, 2021 08:09 PM
Sixer4Life
Oct 12, 2015 04:26 AM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Sixer4Life
Sep 28, 2015 07:05 AM
