Freezing Breaks
Old Jan 24, 2011 | 09:32 AM
NetComrade's Avatar
NetComrade
Default Freezing Breaks
I have an issue described here:
http://www.themustangsource.com/gala...sb06_05_04.pdf
The dealer said it's $400 (200 parts 200 labor)
Seems rather ridiculous for a known issue.. is this normal?
Old Jan 24, 2011 | 09:43 AM
LostBoyz's Avatar
LostBoyz
the parts seem within reason but for an hours work for $200 seems high
Old Jan 24, 2011 | 10:08 AM
kevinmalec's Avatar
kevinmalec
Is your e-brake broken?
There is a TSB out on the ebrakes freezing to the caliper. I just waited until the ice thawed out, then did not use the e-brake the rest of the winter.
It depends on how long it takes them to fix it. Ask them what they charge per hour for labor. VW dealer charges like $90/hr., which is ridiculous!
Old Jan 24, 2011 | 11:26 AM
Nuke's Avatar
Nuke
Many here that have had that issue have had it done at no charge under the TSB. Most dealerships are azzholes and won't do it at no charge if you're out of warranty. You could raise a stink since it IS a design problem but I doubt you'll get anywhere.
I suspect that you could find a good local shop and with the TSB they should be able to do it for you much, much cheaper if you're not considering doing it yourself. The e-brake cable isn't rocket science.
Old Jan 24, 2011 | 11:38 AM
red07Pony's Avatar
red07Pony
Both prices are high IMHO.
http://www.texasmotorsfordparts.com/...layCatalogid=0
I'm sure they have a markup on their parts (profit - not a bad word). But if you can do it yourself, which is what I plan on doing when winter is over, you can save a lot of money! I had the exact same problem and just unhooked the cables from the calipers and don't have a e-brake right now.
Old Jan 26, 2011 | 07:17 AM
baddog671's Avatar
baddog671
Just don't use your ebrake. Leave it in reverse when you get out, as it's your lowest gear. Or first if you're pointing uphill, if you like.
Old Jan 26, 2011 | 09:49 AM
2005Redfire6's Avatar
2005Redfire6
Exposed e-brake cable freezes, not the caliper themselves
Old Jan 26, 2011 | 02:50 PM
kevinmalec's Avatar
kevinmalec
Wink That's what I meant! Thanks 4 lookin out!
jwog666
Dec 27, 2021 08:09 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
treesloth
Sep 28, 2015 07:03 AM
ccdguy
Sep 19, 2015 05:20 PM
Blk Vert
Sep 9, 2015 12:16 PM
