Head Unit Install
Old Mar 28, 2011 | 11:49 AM
HT's Avatar
HT
Originally Posted by yourmyboybh1026
What gauges can you display? I'm guessing there are more than just what you have on your screen.
That's a good question. Let me see if I can find an answer to that...there are quite a few, too many to remember off the top of my head:
- RPM
- Manifold Press.
- Speed
- Eng. Cool. Temp.
- Intake Air Temp.
- Battery
- Ignition Timing
- Mass Airflow
- Throttle Pos.
- Fuel Level
- Baro. Pressure
- Dynamic HP
- Dynamic Torque
- Gear Position
- MPG
- G-Force
Some of them require a bit of setup. The Gear Position requires a gear calibration, and the Dynamic HP and Dynamic Torque require gear calibration and a power run.
I got all these off a video on their site, but I assume they are the same for every vehicle. I'll check when I'm in the car later.
You can also Data Log weeks worth of data to a Flash Drive and then bring up the information on a computer.
Old Mar 28, 2011 | 01:25 PM
yourmyboybh1026's Avatar
yourmyboybh1026
- RPM
- Manifold Press.
- Speed
- Eng. Cool. Temp.
- Intake Air Temp.
- Battery
- Ignition Timing
- Mass Airflow
- Throttle Pos.
- Fuel Level
- Baro. Pressure
- Dynamic HP
- Dynamic Torque
- Gear Position
- MPG
- G-Force
Thats quite a few. I wonder how accurate the HP and torque are. Looks pretty cool!
Old Mar 28, 2011 | 01:58 PM
HT's Avatar
HT
Thanks, I feel like based on the videos I've seen, the HP and Torque are quite accurate if you get your calibrations and power run correct. I'll let you know though. It takes into account tire size, car type, and wind resistance, so it seems pretty accurate.
Old Mar 28, 2011 | 03:50 PM
wayne613's Avatar
wayne613
Originally Posted by allinon72
That is very cool, but even if they still made them I'm not sure I could swallow $600
As HT states, for $600, that's really not bad.
It's an custom setup ARM processor, which gets the job done for the little it needs. Using one of the standard ELM327 chips such as the ODBLink, and similar computer interfaces for ODB-II/CAN-bus reading.
To get similar you could ask one of you're geekier friends to give you a decent HTPC setup, put the ODBLink on with linux/windows and not load the usual GUI and just have the front-end app come up, such as Dashcommand.
Think by the time you were done you'd be over the $600 mark, even with an older setup by the time you get done buying software and hardware. A wireless keyboard with a built-in mouse would likely be a must, since no head-units I've seen have a touch-screen usb out to integrate.
Old Mar 28, 2011 | 10:05 PM
charliebrown266's Avatar
charliebrown266
Very nice,looks really cool!
cbird1177711
Sep 3, 2015 08:43 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
