Painted valve covers
Old Apr 26, 2011 | 10:37 PM
  #21
wcgman's Avatar
wcgman
Looks really nice indeed!
Old Apr 26, 2011 | 11:15 PM
  #22
TPony's Avatar
TPony
Well done!
Old Apr 27, 2011 | 12:26 AM
  #23
92hatchLX's Avatar
92hatchLX
OP, what kind of paint was used?
Old Apr 27, 2011 | 07:37 AM
  #24
allinon72's Avatar
allinon72
High temp primer, regular basecoat, high temp clear. It's best to use all high temp paints, but I had to use a standard basecoat because I wanted them sonic blue.
Old Apr 27, 2011 | 08:59 AM
  #25
MeanStang08's Avatar
MeanStang08
ChopShop Mod-tator
do you or anyone else have experience with using the regular basecoat sandwhiched between the high-temps on how well this holds up??
i was wondering about doing mine this way so i could get the color match better.. not happy with the high-temp reds available to match my dark candy apple red.. which is some of the reason i haven't finished mine..
Old Apr 27, 2011 | 09:09 AM
  #26
allinon72's Avatar
allinon72
I don't have any experience doing this, but I don't think it will be a problem. The valve covers get hot but not that hot. If the paint doesn't hold up, I'll have them powdercoated.
Old Apr 27, 2011 | 10:47 AM
  #27
Mpaint99's Avatar
Mpaint99
I did mine. Take the battery out to get at rear bolts easier.(suggestion) Theres 15 bolts per side. Need a No# 10 and 8 socket. I needed a 1/2 inch socket to remove cold air intake housing. Read the paint cans to make sure your using all enamel or all lacquer. The high temp paint cans some in both. I would not use carb cleaner to clean them which I have read on other sites. I used 1000 steel wool to prep mine. I went to a local bodyshop and for the cost of lunch he baked my valve covers when I was done. Dont lose a valve cover bolt there $7.00 each from dealer. Parts stores dont carry them because of gromet. Took me an hour for driver side, but I had to disconnect all my Nitrous lines. 20 min for passengerside. Take the time too get everything out of way. You dont want to scratch them when reinstalling them. Good luck.
Old May 6, 2011 | 08:54 AM
  #28
allinon72's Avatar
allinon72
Well I will be honest with you guys...I would probably do a few things different if I did it over again.
First, the magnesium really doesn't take paint well. I would probably use adhesion promoter if I were to do it again. When reinstalling the covers, I used painters tape to mask off the edges so they didn't get scratched. When pulling the tape off, the paint came right off in one spot, all the way down to bare metal. This was quite disappointing. I was able to touch the spot up, but it has me worried about the long term longevity.
The best option would be powdercoat.
Old May 6, 2011 | 10:35 AM
  #29
MeanStang08
ChopShop Mod-tator
ooo.. good information.. thanks for sharing that bit.. wonder what type of adhesion promoter is good for magnesium..
Old May 6, 2011 | 11:17 AM
  #30
allinon72's Avatar
allinon72
Regular adhesion promoter should work. I got the covers down to bare metal, which seemed like a perfect service to lay regular primer on. I was wrong.
