Installing side window louvers
Old May 13, 2011 | 07:01 PM
Nuke's Avatar
Nuke
I used the same prep method and materials on my quarter window louvers (glass attachment) and my side scoops (painted body attachment) and both are solid as concrete after almost 4 years.
Old May 14, 2011 | 08:11 AM
D'prived's Avatar
D'prived
Same here. Used the tape that came with the louvers with no problems after two years.
Old May 16, 2011 | 12:46 PM
rogan01's Avatar
rogan01
btw - Nuke - the tube that came with the DGC Louvers appears to be an adhesion promoter. I guess I should use the 91% alcohol first, let it dry, then use the adhesion promoter that came with the louvers?
Just ask because my prior car was a 2006 GT that I had a roush hood scoop on and the adhesion promoter was to adhere the tape to the scoop - not the hood...
Very confusing as it seems in this case I would need to use it between the glass and the tape...
Anyone can clarify? Thanks!!!!!!
Old May 16, 2011 | 03:41 PM
Nuke's Avatar
Nuke
I've never used adhesion promoter so I can't say. IMO, as long as you've stripped the surface of all contaminants you're good to go. I'm still not sure what that tube you have is.
drfister
May 3, 2018 10:38 PM
NorthAmericanTuning
Nov 9, 2016 11:45 AM
spectreman
Mar 31, 2016 09:26 PM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
