Mustang inquiry
Old Jun 8, 2011 | 01:05 AM
l00kitzzlilcj's Avatar
l00kitzzlilcj
Default Mustang inquiry
hey, ive been looking for my first mustang lately and i would like to know some things.. its going to have between manual and 60-70K miles on it because im buying a used v8 between 05-09 so..... 1) what should i look for when buying, like the common problems between those ranges i should check out.. 2) any information about problems in that mileage and 3) any problems you have had at all. thanksss !
Old Jun 8, 2011 | 06:10 AM
2005Redfire6's Avatar
2005Redfire6
I would def. take a look at the TSB's for them!
https://mustangforums.com/mustang-tsb/
Old Jun 8, 2011 | 06:37 AM
Nuke's Avatar
Nuke
The TSB's are the biggies. 2005Redfire6's link above is the way to go. But of all of the TSB's, the one for the water leak is the killer, especially if the car will be your DD.
Old Jun 8, 2011 | 11:16 AM
l00kitzzlilcj
thankss ! i didnt even know that was here lol im new still i just signed up last night
Old Jun 8, 2011 | 03:12 PM
chain1's Avatar
chain1
It might be worth while to narrow your search down to an 07+. That will give you a couple extra features and many of the initial issues will have already been addressed.
Old Jun 18, 2011 | 11:07 AM
l00kitzzlilcj
that does sound like a good idea. i have been looking mainly at 07's and up because ifelt that 05 & 06 were a little older
Old Jun 18, 2011 | 11:36 AM
spower's Avatar
spower
Good luck with your search....I now own my 4th Mustang and outside of my 67 I had way back when, I absolutely love my 05 V6, 5 speed, convertible! Very comfortable and fun to drive.
Old Jun 18, 2011 | 12:23 PM
Orion_240's Avatar
Orion_240
be sure to listen to it very closely, including from outside the car.
Have someone else give it gas.
After that you might start to think about getting a V8.
Old Jun 18, 2011 | 12:44 PM
157dB's Avatar
157dB
Cut & Paste Expert
Water Leak.
Pass side carpet and pad.
Dont buy unless you remove the pass side door
sill and kick panel and pull the carpet back looking
for the tell tale signs of water intrusion.
If they wont let you do this, run away
as fast as you can.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Jan 6, 2016 07:03 PM
chain
Aug 17, 2015 08:52 AM
daytooday
Aug 11, 2015 09:22 AM
