Brighter bulbs
Old Jul 10, 2011 | 12:15 AM
up_yours_7's Avatar
up_yours_7
Default Brighter bulbs
I want some brighter bulbs for the tail lights and blinker lights any suggestions?
Old Jul 10, 2011 | 12:20 AM
Silver0911's Avatar
Silver0911
You can get LED taillights on americanmuscle.com. Bout all I know.
Old Jul 10, 2011 | 12:32 PM
So_Cali's Avatar
So_Cali
+1, I throw on my set of LEDs during the winter months. The fog around here is crazy then.
I found my LED tail lights on eBay for pretty cheap a few years ago, give that a shot.
Old Jul 10, 2011 | 12:35 PM
157dB's Avatar
157dB
Cut & Paste Expert
http://www.superbrightleds.com/
The web address says it all.......
http://www.superbrightleds.com/vehic...mustang/20/758
Your vehicle may require an LED compatible Flasher or Load Resistor
Get the sequential LEDs from MossMuscle and kill two birds with one stone.
Old Jul 10, 2011 | 12:36 PM
up_yours_7's Avatar
up_yours_7
Ok I was mostly looking for just bulbs cause I got a set of tinted tails and the bulbs aren't very bright through them
Old Jul 10, 2011 | 01:10 PM
AzPete's Avatar
AzPete
Adding just brighter regular bulbs MAY overload the factory wiring plus cause more heat in the light, melting the lens.
Old Jul 10, 2011 | 04:24 PM
Art161's Avatar
Art161
You could check to see if Sylvania has Silver Star bulbs for your application. Definitely check the wattage. On most of those bulbs, I think the wattage is the same as the stock bulbs, so overloading the wiring would not be a problem. The trade-off is much shorter bulb life. The fine in California for a "fix it" ticket, such as a burned out bulb, is now up to $114! As for the bulb getting so hot that it melts the plastic, I don't know.
andrew1969
16
Jan 8, 2016 02:48 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
piotrek53
Oct 13, 2015 06:54 PM
kawiguy827
Sep 22, 2015 10:52 AM
unit91
Sep 15, 2015 09:53 AM
