sporadic power drop
Old Aug 2, 2011 | 08:13 AM
  #21
thewarmachine's Avatar
thewarmachine
I drove the stang to work today, and it is not the compressor causing the problem. The AC was off.
It is usually felt when I hold the accelerator at a steady position to cruise at a fairly low speed....35-50. All of a sudden, I feel and hear the engine slow down, even though I have not moved the accelerator. It is reminiscent of the feeling you get when the AC compressor switches on.
Old Aug 2, 2011 | 09:39 AM
  #22
Nuke's Avatar
Nuke
Thinking what might cause this... it almost sounds like a cylinder momentarily cutting out. Are you running aftermarket COPs? A dirty injector?...
Old Aug 2, 2011 | 02:33 PM
  #23
TWOKOOL's Avatar
TWOKOOL
Mine is with the A/C on, shifting from 1 to 2, then 2 to 3, when you get back on the throttle it seems like it takes a second or so to get going, like it bogs down.
Old Aug 2, 2011 | 03:33 PM
  #24
thewarmachine
TWOKOOL, that is very much like mine too. It seems to lunge a little when the throttle comes back in after a lag. I know the butterfly plates do this around 3000rpm (one of the dumbest ideas ever), but it is not that.
I'll have to use my MAF cleaner and inspect the TB.
I have no aftermarket engine parts except for CAI, tune, headers.
Old Aug 4, 2011 | 10:05 AM
  #25
TWOKOOL's Avatar
TWOKOOL
yep,
sounds like you and I are in the same boat. Let me know if the MAF cleaner works and I will make time to do it. We just don't need to throw money at everything it "could" be, only to find out we can fix it for $7.49.
Old Aug 4, 2011 | 12:11 PM
  #26
Nuke's Avatar
Nuke
Originally Posted by TWOKOOL
...throw money at everything it "could" be...
Off topic, but I often accuse our maintenance department of this and refer to it as "Selective Modular Replacement" whenever they goe azz-wild replacing things when they don't have a clue what's wrong.
Old Aug 4, 2011 | 03:50 PM
  #27
TWOKOOL's Avatar
TWOKOOL
"selective modular replacement"
I like that.
I think I got me a new phrase, with props to NUKE of course.
Old Aug 12, 2011 | 09:38 AM
  #28
TWOKOOL's Avatar
TWOKOOL
thewarmachine, did you have a chance to check it out?
I may try to tinker with mine this weekend.
Oct 26, 2015 05:01 PM
Gene K
Oct 21, 2015 11:37 PM
rksnow1
Sep 14, 2015 08:46 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
zanemoseley
Sep 6, 2015 12:58 PM
