Fog light Switch failure need help
Old Aug 15, 2011 | 09:11 AM
defiance772's Avatar
defiance772
Default Fog light Switch failure need help
Last night my light switch broke. Basically the light switch won't pull out for fogs and when my normal driving lights are on the fogs stay on. Is there a way to fix this myself withoput buying a new switch. Thanks guys for the help.
Old Aug 15, 2011 | 10:31 AM
MustangFirstCar's Avatar
MustangFirstCar
You can try taking it out and pulling it apart to fix it, but I would bet on having to buy a new switch.
How did you break it, if you don't mind me asking?
Old Aug 15, 2011 | 10:58 AM
defiance772
I just tried pulling it and didn't pull anymore it was wierd.
Old Aug 15, 2011 | 11:01 AM
MustangFirstCar
So it's like stuck down? Like, you can't pull it out at all?
Old Aug 15, 2011 | 11:03 AM
BigDinTexas's Avatar
BigDinTexas
Did you try pulling it out when the selector was NOT on the On position first? I know mine will only pull out if the switch is in the Headlights On or Running Lights On position...
Good luck.
Don
Old Aug 15, 2011 | 11:22 AM
BigDinTexas
BTW, just came across this in the Classified section... Thought it might be of some use to you... https://mustangforums.com/forum/part...with-fogs.html
Don
Old Aug 15, 2011 | 11:26 AM
defiance772
Hey thanks for all the help guys. Yeah when I turn on my regular driving lights, I can't pull the switch out for fogs anymore. I try pulling and it doesn't stay out it goes back in. But my fog are on though even without pulling the switch out.
Old Aug 15, 2011 | 11:49 AM
Nuke's Avatar
Nuke
Sounds like an internal failure of the switch. Even if you could repair the switch, I suspect it wouldn't be long before it goes again. Bite the bullet and replace it.
Old Aug 15, 2011 | 11:55 AM
defiance772
I never been shot before I don't want to bite the bullet
I guess I'm going to need to buy a new one.
Old Aug 15, 2011 | 10:14 PM
atomicpunk's Avatar
atomicpunk
Looks like the headlight switch is $56.79 at RockAuto http://www.rockauto.com/catalog/raframecatalog.php
Jb145700
Aug 21, 2022 06:37 AM
2007CalSpec
Dec 13, 2020 11:42 AM
Colin Ringle
Sep 15, 2015 09:27 PM
TfcCDR
Sep 14, 2015 12:08 PM
