BAMA Tune - Is there one for the 2011 GT for MPG boost
#22
OP, you mentioned only a 2 or 3 mile each way to work drive? There's your problem. Aside from not allowing the car to run at it's optimum temp (as you already mentioned), you use fuel when you start up each time. That is fuel spent to start the motor and not go anywhere.
I don't think it's the gears so much as the driving scenario. Not much you can do about that... I'm guessing you're losing about a 1/2 gallon to full gallon each tank in just startup waste.
#23
srry, couldnt resist.
at 80 MPH frwy, yeah, 23 mpg avg sounds about right, At 75 mph frwy avg, I notice around 24-25 mpg avg.
#24
I had exactly the same results as Darkshy : )
