Upgrading panhard bar, handling.. Questions
Thanks guys, so the panhard bar and strut mounts pretty much sum it up. UPR sounds like the way to go. So, when adjusting the panhard bar, make sure my cars on the ground? I look forward to the purchase and installation, my brother works at a shop in town so the labor will be a fun learning experience. Thanks again for the feedback guys
So soon I will be lowering my car (probably koni yellows and steeda sports). I will get gt500 strut mounts and the ebaich hardware, along with a panhard bar. Are there any specific panhard bars I should consider or anything I should know about installation, maintenance, adjustments, etc?
Thanks, you guys are a great help :-)
You take the measurements for the PHB with the suspension loaded but you can raise the car to adjust it, unless you can get your car on a lift which is a little easier. It's a very simple installation, but I'm always available for tech support.
M3hunter
Sep 5, 2015 03:42 PM
