Code Issue? NEED HELP
Old Sep 28, 2012 | 02:12 PM
GT 555 KING SNAKE's Avatar
GT 555 KING SNAKE
Question Code Issue? NEED HELP
Here are the codes 2104,2111,2107,2110, I changed the throttle body Motor and the TPS , cleaned the throttle body and the MAS sensor with all the proper cleaners and the issue I get is the 2111 and 2104 code keep coming up making the car run rough, 4.6 Vortech v3 supercharged running 93 octane tune with about 550rwhp.
Old Sep 28, 2012 | 02:57 PM
GT 555 KING SNAKE
ANYONE
Old Sep 28, 2012 | 05:24 PM
steel pony's Avatar
steel pony
The codes 2104 & 2111 are for a faulty throttle position sensor
The codes 2111 & 2104 are for a faulty throttle control module
If you have cleaned it as you have stated, check around the butterflies for anything impeding movement, etc
check that the voltage is correct to the TCM
check that all of your PCM wiring is connected and secure
unplug the battery for 30min and retest for issue
replace the TCM or the throttle body
Old Sep 28, 2012 | 10:04 PM
GT 555 KING SNAKE
I replaced the TCM and The TPS both and am still having the issue, What is the voltage suppose to be for the TCM? I have also unplugged the Battery for like an hour with the same issues, How will replacing the throttle body housing make a difference if all the mechanics work on it? I'm at wits end lol and I have a car show tomorrow
Jb145700
Aug 21, 2022 06:37 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
