2008 Mustang GT Brakes Chirping Sound
Hi. I have taken my car back to the dealer (4) times for a chirping sound coming from the front brakes when applied lightly. Very annoying soung. After charging me for new brake pads at 24,000 miles, the noise came right back. The last time they kept the car for two days and appied grease to pins or something like that and it was good for about 4 weeks and now is back. Today, after there tech spoke with Ford, Ford says its normal to hear that. If that is so, why didn't I hear it for the first three years I owned the car, why doesn't my wife's car do it, whay has no other car I have ever owned done it? They had no answers so I have filed a claim now with Ford. Anyone else had this issue or any suggestions on how to fix? Thanks.
sounds to me like your rotors may have developed a slight lip from wear over the years.
this is normal, and you could have your rotors turned on a lathe to get them back to a completely even surface.
without looking at it I am just speculating so don't take my word as the absolute answer.. but any reason you insist on going to the dealer when they are not providing you with quality service? I bet you a performance shop or a brake shop would have diagnosed this a lot quicker, and you are not likely going to receive warranty work on a wear item.
they really should stand behind their work, but if they are trying to tell you it's normal, they are more or less blowing you off because they can't figure it out. did you try speaking with upper management there? not just in the service department, but speaking to the GM or another high ranking person at the dealership?
it sucks - maybe your claim with Ford will get you a better response, but you may be able to get resolution quicker elsewhere.
word of mouth goes a long ways when there are bad experiences. if you speak with upper management and they aren't willing to help, you can always hit them where it hurts.. leave negative reviews on google reviews, yelp, dex knows etc.. customers will see this sort of thing when they are looking em up.
Here's a thought:
On my GMC truck W/4 wheel disk brakes, the rears started making "chirping" sounds.
I'd replaced the rotors with Powerslots a few years ago and living in the rust belt, they were beginning to corrode.
Once I took the calipers off, I saw that the chirping was the outside circumference of the rotors (on both sides) contacting the spring clips on the calipers.
I removed the rotors and ground down the O.D. a bit using a bench grinder. I then bent the clips a bit outward to avoid further rotor contact.
Problem solved.
Problem solved.
Hi. I have taken my car back to the dealer (4) times for a chirping sound coming from the front brakes when applied lightly. Very annoying soung. After charging me for new brake pads at 24,000 miles, the noise came right back. The last time they kept the car for two days and appied grease to pins or something like that and it was good for about 4 weeks and now is back. Today, after there tech spoke with Ford, Ford says its normal to hear that...
I'm happy to jump in here and see how I can assist. Send me a PM with your VIN, dealer, mileage, daytime phone number, and full name; I'll look into some options.
Thanks!
without looking at it I am just speculating so don't take my word as the absolute answer...
Here's a thought:
Problem solved.
Problem solved.
Have a great weekend,
Crystal
