Squeaking whining something
Old Jan 18, 2013 | 10:23 AM
cema93's Avatar
cema93
Default Squeaking whining something
Ok i have been reading a lot of thread on a lot of forums and I can't find the exact answers to my questions. hopefully yall can help.
My car whines and squeaks. it is coming from up front. I am fairly sure it has to do with the belt, idler pulley or tensioner pulley. I have a 2005 mustang gt. It drives me insane listening to it and it is so embarassing. Is my idler pulley ribbed or smooth? what would u all say I need to replace? I had a guy from a shop show me that when u pour a little cup full of water down onto the belt, it goes away for a few seconds to a couple minutes. IDK if that helps any. thx for a speedy response.
Old Jan 18, 2013 | 12:48 PM
AMWill's Avatar
AMWill
Former Sponsor
OP,
It's impossible to just assume which pulley, idler, etc., is loose from just a description. The best thing to do is take the belt off and spin each one by hand. You should be able to get a few squeaks out or feel a resistance when spinning the bad pulley. Also, hows the condition of the belt? A worn out accessory belt can cause squeaks, too!
Shane
Old Jan 18, 2013 | 02:35 PM
FrostByte's Avatar
FrostByte
^^^^ yup^^^^
I have an idler wheel that dosnt last long before it starts to squeak, when car is 1st started, because its behind the SC & mounted to engine block and gets hot. PIA to change.
Old Jan 18, 2013 | 03:40 PM
Roy_R's Avatar
Roy_R
Please makes sure you know the whereabouts of your cat before you continue troubleshooting this issue!!!
Old Jan 18, 2013 | 08:38 PM
jpplaw's Avatar
jpplaw
If water will make the squeak go away, then the problem is the belt. Try a Gatorback belt. Worked for me.
Old Jan 19, 2013 | 07:23 PM
cema93's Avatar
cema93
^^ that's promising. I'll change belt. See if it squeaks. If it does ill replace a pulley.
KingRando
Oct 1, 2015 11:16 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
Beerman309
Sep 19, 2015 01:16 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
91StangOwner
Aug 20, 2015 11:34 PM
