Sponsored by:
Sponsored by:
Headlights and fogs on a gt
Old 05-04-2013, 11:14 PM
06gtman
06gtman's Avatar
Is it possible that the low beam elements are burned out and the bulbs just need replacing?
06gtman is offline
Old 05-05-2013, 12:22 PM
06gtman
06gtman's Avatar
Alright, I have checked all the fuses, relays, and even the wiring harness behind the switch. Nothing still no lowbeams and fogs at the same time. The only thing I can think of is that either the switch is bad, or I have a bad ground. Does anybody know where the headlights ground in these cars?
06gtman is offline
Old 05-05-2013, 03:21 PM
Nuke
Nuke's Avatar
And are your high beams working (just in case you're mistaking your high beams for lows...)?
Nuke is offline
Old 05-05-2013, 06:08 PM
06gtman
06gtman's Avatar
Yes, when the highs are switched on, the blue high beam light is displayed on the gauge.
06gtman is offline
Old 05-05-2013, 06:14 PM
White05GT
White05GT's Avatar
Do your low beams work without the fogs on?
White05GT is offline
Old 05-05-2013, 06:33 PM
06gtman
06gtman's Avatar
White05gt, no, when I turn the switch to the symbol, with the "p" just the marker lights turn on. If the ignition is on, and I pull the switch out, the fogs turn on. If I turn it one more notch, I get the brights, and the fogs turn off. Which from what I understand is normal.
06gtman is offline
Old 05-05-2013, 06:55 PM
White05GT
White05GT's Avatar
All that sounds normal. What I'm wondering is if your low beams work fine WITHOUT the fogs being turned on.
Old 05-05-2013, 07:58 PM
AzPete
AzPete's Avatar
When the brights are on....does moving the turn signal switch towards front or back of the car change the headlights from high to low?
In the "p" position, you only get the marker lights and fog if switch pulled....that is normal. Almost sounds like you are not operating the high/low switch properly.
AzPete is offline
Old 05-05-2013, 09:19 PM
06gtman
06gtman's Avatar
Ding, ding, ding. we have a winner. Thank you!! I feel like a big stupid goofball. Thank you AZpete. Thats is what was wrong. Thank you for all the help. I appreciate it. Gosh I feel like an idiot.
06gtman is offline
Old 05-06-2013, 08:28 AM
AzPete
AzPete's Avatar
Lol......don't feel bad...most of us have done small stupid things.....just glad we got you going.
AzPete is offline
StalkerGT
11-28-2015 03:09 PM
jhawkr
10-30-2015 01:55 PM
Seanam
10-04-2015 10:15 AM
Drastang
09-29-2015 03:31 PM
Colin Ringle
09-15-2015 09:27 PM
Quick Reply: Headlights and fogs on a gt
