Best Boosta Pump?
Old Jun 4, 2014 | 08:37 AM
UPRSharad's Avatar
UPRSharad
Former Sponsor
Originally Posted by fivo2go
I already have the dual gt500 pumps. the shop that I took it to for a new tune says its running extremely lean and that I should go to a boosta pump and 60lb injectors. Car has Saleen Series VI supercharger and before I took it in made 497 rwhp. Now that they messed with it only 456 rwhp. And it runs really rich. Don't know what they did to it. Just runs like crap.
I went through that too. I was running FRPP 47s and going lean so we added the JMS PowerMAX. It helped, but the injectors couldn't keep up so I swapped to these DW60# injectors and they fixed the problem. No more lean condition, and their drivability is perfect!
Old Jun 4, 2014 | 10:37 AM
fivo2go's Avatar
fivo2go
Well I found out why it running so bad. Had 4 coils go bad (scan tool only said 1). Replaced all 8 and runs much better. Imagine that. But the shop still says I need the Bap and 60lb injectors. Could I just do larger injectors or will there not be enough voltage or fuel?
Old Jun 5, 2014 | 04:07 PM
UPRSharad's Avatar
UPRSharad
Former Sponsor
I would try those injectors I showed you first. They might give you the fuel you need without the BAP. Whereas, all the fuel pump voltage in the world will only supply so much fuel before you max out the existing injectors.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
Bokeo
Oct 10, 2015 08:28 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
mrappe
Sep 26, 2015 10:16 AM
