Timing chain guide/tensioner problem
Old Apr 3, 2019 | 05:58 PM
AndrewG's Avatar
AndrewG
Default Timing chain guide/tensioner problem
Recently the one of the guides/tensioners on my timing chain broke. The broken part shattered my valve cover.
We're trying to replace it but I can't figure out what the part number is.
This is on a 2006 4l v6 with automatic transtransmission.
I think thats where the broken part came from
The broken bit
The pictures aren't great but could anyone point me in the right direction? Also any advice on checking and getting bits of the valve cover out?
Old Apr 3, 2019 | 06:47 PM
08'MustangDude's Avatar
08'MustangDude
Banned
Common problem..
If you can't see the "bits" up top, the "bits" are no longer in the valve cover. They fall
all the way down...
Old Apr 3, 2019 | 08:39 PM
5.Oz's Avatar
5.Oz
rockauto is where i get my parts. just use the drop down menus to find the right parts. looks like you'll need a timing chain tensioner and a timing chain guide. buy motorcraft parts when possible. when those aren't available, id recommend cloyes parts, as i replaced all of those components in my 1999 4.6L with that brand and she's still romping around w/ 177000 on the odometer. absolute pain in the *** to replace tho.
Old Apr 4, 2019 | 10:53 AM
AndrewG's Avatar
AndrewG
Are the guides and tensioners the same for the automatic and the manual? On rockauto I've only seen the ones for the manual.
Old Apr 4, 2019 | 01:26 PM
Derf00's Avatar
Derf00
Gentleman's Relish
The difference is with or without balance shaft if you are looking at a complete Timing Chain Kit. I don't know the difference on the msutangs. BTW Cloyes and Melling are the two that actually make the OEM Ford parts so, you can't go wrong with either.
99BlackPonyGT
Nov 13, 2007 04:14 PM
2000GTFOOL
Jul 27, 2007 11:49 AM
JohnnyK
Oct 30, 2006 08:19 PM
edh1005
Apr 8, 2006 12:51 AM
rick98gt
Mar 18, 2006 09:55 PM
