Weird issues
Old Oct 1, 2019 | 08:31 PM
caden_oquinn's Avatar
caden_oquinn
Default Weird issues
So I was having ac problems and I replaced the ac clutch duo ads and it was fine and worked for a few weeks . But then my stated acting up agin and wouldn’t cut on so I went and checked the fuses and relays and I switched them around and it turned ok I have a bad relay so I went and got all new relays just to be safe . So I was sitting at a long long long red light and notoced it was starting to overheat and I turned my ac on to turn the fan on and nothing neither turned on so I pull over and i didn’t even switch the relays I just unplugged them then plugged them back in the same spot and the ac kicked on then I did the same for the fan and it worked . So for the past few days when I go to work I turn my ac on and itdosnt come on so I get out and unplug and replug the blower motor really and it works and I can’t seem to firgiure our what the problem is because the ac works fine after I do that and so does the fan but it doesn’t work until I jump them off
caden_oquinn
Oct 1, 2019 08:27 PM
Moesakr
Dec 2, 2017 09:34 PM
GSPmustang
Jun 22, 2010 09:31 PM
guno89
May 25, 2009 12:24 PM
Jailhouse Jim
Apr 9, 2007 11:16 PM
