SHAKER HELP NEEDED
Old Jan 21, 2020 | 04:55 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Glad you found the problem!
The inside of the unit could have a bad ground but unless you have a schematic of the guts, good luck. You would be best off just buying another head unit. Make certain it is the same part number as the one you want to replace.
What Raxiom harness are you talking about? If that's plugged inbetween your head-unit and your speakers THAT could be the issue.....
Old Jan 21, 2020 | 05:13 PM
Brandon197's Avatar
Brandon197
Uhmm.... the harness that plug into the factory stuff and goes into the back of the sync unit... uhm, I kinda like the look of the factory unit honestly. I actually think it’s sounds pretty good... 2 door speakers, 2 8” subs in the doors plus the rear deck. Not too shabby
Old Jan 22, 2020 | 10:16 AM
07 Stang's Avatar
07 Stang
Haven't really looked into it, but do you guys know if the Shaker 500 has an option to add a bass tube? I guess I will have to add an amp to it.
Old Jan 22, 2020 | 10:57 AM
Brandon197's Avatar
Brandon197
That’s just a sub but in tube form right? Lol, either way I feel like if you’re going to add an aftermarket sub I’d ditch the factory amp and use an aftermarket one. Just make sure the outputs are the same. I’m not a huge audio knowledge guy but I think if the speakers and subs have different ohms and the amp is too strong or too weak it can cause blowouts. Don’t quote me though!
Old Jan 22, 2020 | 12:40 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Okay, I'm a little confused.
Raxion is an aftermarket wiring harness that plugs into a factory head unit and the factory harness?
Why would you need an aftermarket wiring harness if it's all OEM? Did you swap out the original OEM head unit with an upgraded OEM unit and use an aftermarket (Raxiom) harness to make the connections since the upgraded OEM headunit does not match the OEM harness on your car?
Old Jan 22, 2020 | 04:11 PM
Brandon197's Avatar
Brandon197
So this harness has the regular sync connections as the OEM harness, as well as stuff specific to the Raxiom unit. All I did was unplug it and plug the factory stuff back in and BAM!
Old Jan 23, 2020 | 05:37 AM
Siber Express's Avatar
Siber Express
You might want to look in the rubber tube the wires run through from the body to the door, it almost sounds like a Frayed ground wire
Old Jan 23, 2020 | 06:06 AM
Brandon197's Avatar
Brandon197
This issue has been resolved everyone! Thank you for everyone’s help but the culprit was the Raxiom headunit. Guess it has some internal issue(s).
Old Feb 7, 2020 | 04:36 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Thank you for confirming the issue! Glad you got it fixed!
Brandon197
Jan 11, 2020 04:22 PM
kyleking777
Apr 16, 2012 02:56 PM
zaha
Mar 16, 2008 12:04 AM
RideCRF450
Mar 5, 2006 01:07 AM
Grog
Oct 5, 2004 09:46 PM
