P0300 only under max load?
Old Aug 5, 2020 | 07:03 PM
dg8882's Avatar
dg8882
Default P0300 only under max load?
06 GT, owned the car about a month and i decided to push it to its limit today. I was in 4th gear just above 5000 rpm and flooring it when I noticed power seemed to be leveling off and then it misfires. It has never done this in normal or even spirited driving and only happened very breifly, as soon as I heard the misfire I let off the gas and it immediately went away.
I plugged in my scanner as soon as I got home and found P0300 for random misfire. Due to it happening only at max load and not specific to one cylinder my first guess is a clogged fuel filter which I will be replacing tomorrow. Fuel trims also seemed to be high indicating a lack of adequate fuel?
Anyone else have ideas if that doesn't do it?
Old Aug 6, 2020 | 02:03 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
Replacing the fuel filter might just work but I suggest you pour a bottle of fuel injector cleaner into your next tank of gas. That random misfire and lean condition could be due to clogged injectors.
Helgi
Aug 7, 2013 09:40 AM
michaellittle88
19
Jun 23, 2011 11:29 AM
snafu7x7
Jul 23, 2008 03:37 PM
devongarver
May 18, 2008 06:08 PM
Mach1351C4v
Jul 15, 2006 06:42 AM
