Right taillight and right parking light stays on
Old Nov 16, 2020 | 09:30 AM
David Austin's Avatar
David Austin
Default Right taillight and right parking light stays on
I have a 2006 GT and the other day I noticed the right taillight and right parking light is on when the car is off. Also some times now the power locks and windows won’t work when the car is running also fog lights won’t work, headlights go out sometimes just one. When I change stations on the radio no sound. If I shut the car off sometimes things will work but the taillight still will not turn off. I bought the car used a couple years ago and had the problem that a lot of people had with water leaking down around or through the fuse box due to the under hood drain being clogged so I’m guessing this might have something to do with it. I have a appointment to have it checked out in a few days at the Ford dealer. Anyone else have this type of problem or information? I’m worried about the cost to track it down.
Thanks
Old Nov 16, 2020 | 12:26 PM
Derf00's Avatar
Derf00
Gentleman's Relish
It is most likely related to the SJB (fuse box) in the passenger side footwell. You can remove the cover and inspect it for corrosion. 2005 and 2006 are prone to that problem and some people fixed it by replacing the box, without addressing the actual problem. The problem is water leakage, not just from the cowl.
Here's a link about all of the potential leak locations and their resolution. : https://latemodel.cachefly.net/downl...sb08-26-07.pdf
stang2002
Apr 25, 2014 07:02 PM
akp20032004
Mar 3, 2008 06:32 PM
acstang96
Nov 7, 2007 08:57 AM
Troteck
Aug 22, 2006 04:33 AM
mustang_cab
May 14, 2006 05:05 PM
