fog light hook ups
RE: fog light hook ups
did you put bulbs in? lol jk
could be about 4000 things
-fuse
-short
-burned out bulb
-broken switch
-bad ground
-bad power
its really hard to narrow down electrical without lots of information or looking at it... somewhere in your setupid you most likely missed one stupid little thing that will take 4 seconds to fix lol.. good luck!
-fuse
-short
-burned out bulb
-broken switch
-bad ground
-bad power
I'm actually having the same problem. I had one bulb out so I replaced it 4 days ago and I noticed last night that neither light is on now. Granted I haven't pulled the bulbs or looked at fuses yet but found it strange that I would put a new bulb in and 4 days later both wont light.
It's surprising how bulb life can be so close. I've had a couple of times when bulbs that are used simultaneously have burned out close together. That's why when you change one bulb that's been in for awhile, you go ahead and change the other one.
jwog666
12-27-2021 08:09 PM
09-25-2015 09:06 AM
