PCM or not PCM
Old May 28, 2024 | 04:23 PM
rpc's Avatar
rpc
Default PCM or not PCM
Greetings...I have been spending too much time trying to diagnose my 2010 4.0L Mustang. Seems to run fine then I get all sorts of codes and drive ability issues. On my X-Ray scanner I get emission codes,purge valve and vent codes, egr codes, O2 sensor codes both lean and rich, The scanner shows the the voltage of both banks moving toward zero.O2 sensor heater codes. The fuel trims are high positives. The AC compressor shows engaged on the scanner but the clutch is not physically engaged. Only the low fan comes on and the scanner shows engine temps @224-228. High speed fans does not come on. Then later I can start the car and all the vitals and trims and ac are working great! ...until i think it heats up. I cannot believe all of the components are defective.. Anyone have the pins outs for the pcm conectors where I can do some signal checking. I cannot find them. BTW...I checked the battery voltage with a scope and found literally no noise greater than maybe 50mv.
OM3GA
Jun 24, 2021 01:48 PM
Daviddrivesbetterthanyou
Aug 21, 2019 11:11 PM
Ressa
Aug 15, 2017 01:28 PM
Roushstracer01
Dec 29, 2011 10:07 PM
CJFANNI
Jun 17, 2006 05:02 PM
