sequential turn signals, easy or hard?
Old Nov 28, 2005 | 11:36 AM
Hoof_N_It06 GT's Avatar
Hoof_N_It06 GT
Default sequential turn signals, easy or hard?
i was just thinking about installing the sequential turn signals and was just wondering what the install consisted of and if it was hard to do or not, thanks for the help.
Old Nov 28, 2005 | 12:09 PM
VaporDude's Avatar
VaporDude
Default RE: sequential turn signals, easy or hard?
The kit that I got took about 45 minutes to install. I took out both tail lights and worked on them on a work bench then reinstalled them and made my final connections. Easy to do and not too long to install.
Old Nov 28, 2005 | 02:07 PM
RFortuna's Avatar
RFortuna
Very Easy. They basically plug right in to your wiring harness. You have to remove the trim panel that covers the trunk latch, and unbolt both tail lights. That's about it.
Randy
Old Nov 28, 2005 | 02:25 PM
RedAlertlb's Avatar
RedAlertlb
It depends on where you buy them i have seen some kits that just plug into the stock harness and others that you actually have to tap in to the wires.
Old Nov 28, 2005 | 04:25 PM
SpikeGT's Avatar
SpikeGT
pretty easy, about 45 min to 1 hr.
Old Nov 28, 2005 | 09:57 PM
BigFloppy's Avatar
BigFloppy
Even my 11 old nephew could figure this one out the hardest thing was removing the tape and cutting pin 2 wire
No biggie, took under an hour end to end
Old Nov 28, 2005 | 11:54 PM
Goldenpony's Avatar
Goldenpony
Check out the Chaser Light kit on Meter4it.com. Much cooler than the regular sequential lights
Meystang
Sep 25, 2015 04:05 PM
Sminemann
Sep 17, 2015 09:24 AM
TheDutchTexan
Mustang Videos
Sep 10, 2015 06:51 PM
Dragonus18
Sep 9, 2015 01:21 AM
amandahchase
Sep 3, 2015 10:09 AM
