LSD
Old Jan 12, 2006 | 12:48 PM
Juntech's Avatar
Juntech
Default LSD
Has the mustang always had the Limited Slip on the V8's? Does it help in the corners?
Old Jan 12, 2006 | 01:04 PM
The Ghost's Avatar
The Ghost
Default RE: LSD
Limited slip is good on all dry roads, wether going straight or in the twist. The nature of it is it will allow for the wheels to turn at different speeds once torque gets so high. In the twistys you get the benifit of having both wheels pulling and so you don't end up with the inside wheel lifting and spinning (open diffs do this). Due to the ability of the LSD to allow the wheels to slip a little you also never have a siuation when you drag a wheel due to wheel speed differences when turning (true lockers do this). Downside to any type of traction aid is lateral stability on slippery roads. You want one wheel non powered on slippery roads to maintain side to side traction. Two spinning wheels on ice=back end coming around. Our TCS tries to correct this by keeping the wheels from spinning loose by applying the brake slightly to the spinning wheel.
Old Jan 12, 2006 | 02:44 PM
hawgman's Avatar
hawgman
I ♥ Acer
Default RE: LSD
OK fine.....jack with the old hippie by calling the thread LSD...yea, thats funny..haha....NOT.
Old Jan 12, 2006 | 05:45 PM
Juntech's Avatar
Juntech
Default RE: LSD
ORIGINAL: The Ghost
sounds like a solid system, does the TCS limit the torque on dry roads during a turn? Anyone push the Stang to the limit in corners? Man, i wonder how much the TCS system restrics wheel slipage because in my current car the absolute limit is when the tires are squealing like a piglet. [:-]
So is the 05+ the first year with an Limited Slip Diff?
Old Jan 12, 2006 | 05:47 PM
Juntech's Avatar
Juntech
Default RE: LSD
ORIGINAL: hawgman
hahaha, you'd think LSD could mean one of two things in a car forum. I guess you're a druggy
Old Jan 12, 2006 | 06:13 PM
The Ghost's Avatar
The Ghost
Default RE: LSD
UHH....Traction Control should be off unless the roads are slippery (rain, snow, ice) The only time it works is if wheel spin is sensed. It works two-fold: It softly applies brake to spinning wheel, it limits RPM/torque to keep the other wheel from spinning. I CAN NOT POWER BRAKE THIS CAR WITH THE TC ON. I can power brake it mightily with the TC off.
nonstopred
Jul 31, 2006 12:34 PM
V6MustangKnight
Jun 20, 2006 10:03 PM
HxCory
Jun 2, 2006 06:15 PM
TJ
May 16, 2006 08:52 PM
Big Red
Mar 6, 2006 10:25 PM
