Sequential taillights
Old Feb 13, 2006 | 06:32 PM
  #21
sowaxeman's Avatar
sowaxeman
Retired Moderator
Default RE: Sequential taillights
ORIGINAL: RICVA05
ORIGINAL: Stoenr
http://www.webelectricproducts.com/
139 if you send your stock harness back. Quick and easy install, works great on my 06.
That is the same company I used with my 05. Very easy install.
Just buy the splice in kit from Web Electronics! Save about $70, and no worries about harnesses. If you can read, and have a pair of wire cutters and strippers, you are good to go. I installed mine AND my neighbors in less than 90 minutes time for both. Just too damn easy to worry about harness, sending back parts and all that jazz.
Old Feb 13, 2006 | 08:13 PM
  #22
lmmmmm's Avatar
lmmmmm
the problem with a splice kit is you cant go back to the OEM stock harness without showing your handiwork. and if you have any electrical problems that could void warranty work.
there was a place that had a splice kit that didnt affect the harness but so far it is only good on pre Nov 2005 models.
Old Feb 13, 2006 | 09:15 PM
  #23
austijc's Avatar
austijc
ORIGINAL: lmmmmm
That's what I was thinking. Just ordered a set from webelectric but will probably hold onto my stock harness just in case.
Old Feb 14, 2006 | 11:28 AM
  #24
sowaxeman's Avatar
sowaxeman
Retired Moderator
The Splice in kit does NOT eliminate the factory harness - you simply splice in 3 wires after it. So it is still in tact, if you need to take them out, you just cut out the splice in wires, re-insulate and your done.
Old Feb 14, 2006 | 04:09 PM
  #25
lmmmmm's Avatar
lmmmmm
True, but you have to cut into the wires and you cant hide the fact that you modified an electrical connection. It's up to each owner to decide what they feel comfortable doing while their warranty is in effect.
ORIGINAL: sowaxeman
Old Feb 14, 2006 | 04:24 PM
  #26
crazangel14's Avatar
crazangel14
ORIGINAL: BigFloppy
www.meter4it.com
Easy to install, yes it's an electrical mod only (with the addition of a control box)
Takes about 45 minutes to install (ish)
when you install these.. my question is.. does the sequence carry on all night while the lights are on.. or only turnning?
Old Feb 14, 2006 | 04:47 PM
  #27
28HopUp's Avatar
28HopUp
MF Administrator
crazangel14 Date 2/14/2006 2:24:07 PM
quote:
ORIGINAL: BigFloppy
www.meter4it.com
Mine is from www.meter4it.com, and I keep it in Chaser mode. Parking lights are not affected by the kit. The bright taillights flash out in sequence with the turn signals on or the 4-way flashers. When the brakes are applied, they strobe out and stay lit until I remove my foot from the pedal, at which point they finish their cycle and chase to the outside edge of the car. In sequential mode (with this kit at least), all six brake light bulbs turn off together.
Old Feb 14, 2006 | 07:25 PM
  #28
RICVA05's Avatar
RICVA05
ORIGINAL: crazangel14
When you install these.. my question is.. does the sequence carry on all night while the lights are on.. or only turning?
They only sequence when brake or turn signal is used.
Old Feb 14, 2006 | 07:38 PM
  #29
crazangel14
ORIGINAL: 28hopup
quote:
ORIGINAL: BigFloppy
www.meter4it.com
so when you say u brake and they stay lite/ then u remove ur foot from brake and they continue the pattern.. does that mean while your drving .. your foot on the gas.. no blinker on not even the hazard lights.. the lights are still beaming in the pattern? or no they just stay lite like the normal stock lights? lol this really bothers me cause theyr really cute just i dont want to confuse other drivers and cause an accident of some sort
Old Feb 14, 2006 | 07:39 PM
  #30
crazangel14
ORIGINAL: RICVA05
ooo okay answers my question.. i was just confused with 28 hopup
SilverStallion05
Sep 5, 2015 10:48 AM
amandahchase
Sep 3, 2015 10:09 AM
kdryan
Aug 21, 2015 04:01 PM
philster0306
Aug 10, 2015 11:33 AM
V6 Mustang Stuff
Nov 22, 2004 10:16 AM
