I like your style man care to share what other exterior mods you plan on doing? Also when is that suspension going on?
Ill be ordering Caster Camber plates from Sam Strano this evening. Then they get here the suspension will go on the following weekend. My other exterior plans change as I research more and more. I can tell you I will be having custom side badges made soon and Im working on a design for a custom rear badge replacement. Oh and clear marker lights front and rear. I think the clear will be less distracting in a side view. Also, if I can get some time, Im going to try to fab up a higher kick up gurney flap out of aluminum.
yellow tint from HeadlightArmor. If you look on their site, my car is in the picture for the street scene center fog grille cut film. The stock type are sectioned at the top like the stock grille so I had to measure for them and tell them the full circle size I needed. After I sent in pics, they refunded my money.
Do you know if the measurements are the same for center fogs on S197's?
I cant be sure. I think the only reason they had to cut different sized ones for my application is that the 10 and ups have the top portion of the fog hidden behind the stock grille. Your car is likely same size either way. And as a note, the 2010-11 are still S197s.
