3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Can you adjust the mileage meter?
Old 02-15-2012, 05:04 PM
WORKISSLOW
WORKISSLOW's Avatar
Default Can you adjust the mileage meter?
Maybe I am searching with the wrong words but there has to be some info on the subject some where?
I just want to know if the miles per gallon gauge/meter can be adjusted to it is at least sort of close to reality.
I have over 10,000 miles on my car and the Average Miles per gallon crept up from 12 mpg to around 24.4 (at the moment) but it usually reads around 22-23 mpg. It stopped getting closer to real mileage some time ago.
Naturally I hand calc it and it is usually from 25.4-27.2.
https://mustangforums.com/forum/3-7l...w-mpg-win.html
https://mustangforums.com/forum/4-6l...l-gauge-2.html
WORKISSLOW is offline
Old 02-18-2012, 11:46 PM
2011V6Conv
2011V6Conv's Avatar
You can reset it so it starts calulating from scratch again.
However, everyone seem to observe that it reports MPG that is somewhat lower than what they manually calc
2011V6Conv is offline
Old 02-20-2012, 01:47 PM
WORKISSLOW
WORKISSLOW's Avatar
My Average MPG gauge/meter usually reads some where in the 23.Xs.
Last monday evening I filled up and I decided I would see how good of mileage I could get. Previously I would pencil mileage when I filled up, my worst tank was about 24.7 mpg and my best was around 27.2, and of course most of the time I was some where in the middle (prolly like 25-26 mpg.)
So I started with a fresh full tank on Monday evening and filled up Friday evening. The stang only took 10.2 gallons, I think the gas gauge said I had about 1/4 tank left. I had traveled 295.7 miles since Monday, so I netted 28.99 MPG.
All I did was set my cruise at the speed limit on the freeway and accelerate more gently. I have decided I can coast down hill more as well has coasting up to stop lights/signs. I am starting to think it won't be that hard to actually average 30 mpg. I have noticed a slight increase in MPG even before I started my little experiment, It could be the colder air, less AC and the Amsoil, My guess is that all 3 contribute.
Since I started driving real careful the Average MPG meter/gauge has started creeping up, it was consistently under reporting before. It was hanging down there around 23.xs. This morning it was at 25.1. I gain about 0.1 a day. Now I am wondering if it will ever catch up to my calculated mileage?
Old 02-20-2012, 05:28 PM
Moderator
JimC's Avatar
You have to reset the MPG each fill up. It is taking an average over time since it was last reset. So if you don't manually reset it then you are looking at what you averaged over the last 10 or so tanks of gas.
I've found that it is pretty accurate on my car. I reset it each time I gas up and when I've done the manual calculation the MPG on the display is always within a tenth of the manual calculation.
JimC is offline
Old 02-20-2012, 05:56 PM
WORKISSLOW
WORKISSLOW's Avatar
Oh, your suppose to reset it each time?
i guess that makes sense.
Old 03-14-2012, 02:26 PM
WORKISSLOW
WORKISSLOW's Avatar
I started resetting the MPG display after each fill up and it is more accurate. Though it is consistently under reporting MPG. It typically reads 26.2-26.4 MPG. The last three tanks calculated out like this, 29.0, 30.1, 29.2. So the MPG display is off by at least 2.5 mpg.
cr620
10-03-2022 10:18 PM
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
UrS4
10-03-2015 06:23 AM
winner99
09-30-2015 07:04 PM
Quick Reply: Can you adjust the mileage meter?
