3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
If you have 2013 V6/auto/stock...question on RPM in 4th gear
Old 03-14-2014, 06:04 PM
Moronix
Moronix's Avatar
Question If you have 2013 V6/auto/stock...question on RPM in 4th gear
If you have a 2013 V6/automatic and stock can you try this in your car and tell me what happens?
Using select shift get in 4th gear and around 50mph. Then floor it and watch the Tach. Mine goes up for a couple seconds and then drops about 500 rpm. Then slowly goes back up again. What's that about ? Anyone else see this?
Moronix is offline
Old 03-15-2014, 09:40 PM
staggolee
staggolee's Avatar
I don't have an automatic but since no one else is chiming in and I'm curious:
Could it just be going into overdrive?
staggolee is offline
Old 03-19-2014, 10:42 AM
ColinW627
ColinW627's Avatar
I'll try it in a few minutes on my break and get back to you.
ColinW627 is offline
Old 04-03-2014, 03:28 PM
289hipo
289hipo's Avatar
It's the rev limiter kicking. apparently your over doing it in 4th.
289hipo is offline
Old 04-03-2014, 05:36 PM
Chromeshadow
Chromeshadow's Avatar
When you are cruising with an auto, the torque convertor locks up. When you tap the gas, it should unlock and your RPMs should go up about 500 RPM. When you let off the gas a little, or when it runs out of power at higher RPM, it will lock back up. Not sure if yours is normal from your discription.
Chromeshadow is offline
Old 04-04-2014, 10:17 AM
Moronix
Moronix's Avatar
Thanks for the explanation. That appears to be what is happening. I honestly don't like this transmission because of this type of action. It seems "soft" or like it's slipping. I would like a firmer feel from the transmission. I traded my '07 stick shift GT/CS for this car and I like everything except the transmission feel.
Moronix is offline
Old 04-04-2014, 11:46 AM
StangDawg
StangDawg's Avatar
I have the exact same car and feel the transmission could shift a bit better, that's why my next mod will be a tuner as this seems to take care of the issue once and for all. Done deal
StangDawg is offline
Old 06-23-2014, 06:43 PM
Firebird71
Firebird71's Avatar
I agree with your comment on the shift points. As soon as we get a tuner for this car were gonna have to work on the shift points. I hate them. Guess I'm used to the shift points on our 07 gt convertible. What's a good tuner? I'm thinking bama but would consider others.. We have sct on our 07.
Firebird71 is offline
mtgldr
02-03-2024 09:00 PM
JDWalton
09-24-2015 08:47 PM
heslekrants
09-23-2015 04:02 PM
musnicki
09-23-2015 07:11 AM
stealth_GT
The Racers Bench
09-22-2015 02:19 PM
Quick Reply: If you have 2013 V6/auto/stock...question on RPM in 4th gear
