351 Mustang
heads
Old Nov 6, 2006 | 11:51 PM
Cleeman99's Avatar
Cleeman99
Default heads
ok i got a 351w outa f-250 and the heads r no good as fars as making any power now i was woundering if i had the heads cut for lagger valves and milled and ported and polish if it would make some good power i was thinking of running
-intake 2.02, -exhaust 1.60
-a good cam (any help on desision welcome)
-some good push rods (any help on desision welcome)
-crane cams valve springs (any help on desision welcome)
-crane cams retainers and keepers (any help on desision welcome)
any help welcome thx
Old Nov 16, 2006 | 09:38 PM
Indy's Avatar
Indy
Default RE: heads
Hi,
Get some prices together from some reputable automotive machine shops. You'll probably find that modifying the stock cylinder heads will not be as inexpensive as you would aniticipate (after machining, valves, springs and spring hardware etc...). Even worse, depending on what power levels you are expecting, they may still lack the capabilities. It would probably be more cost-performance effective to go with aftermarket aluminum heads with the specs you want... Eddy's and TFS heads are a good price and proven to boot! Also, set a goal for your build cause the rule is "bigger is not always better".
Best of luck.
Old Nov 18, 2006 | 10:40 AM
S351R13's Avatar
S351R13
Default RE: heads
Just like Indy said. You can just about buy a new set of heads for what you will spend on a new set of aftermarket. Even working those stock heads won't get you the performance of a bolt on set of aftermarkets.
Old Nov 19, 2006 | 07:12 PM
Cleeman99's Avatar
Cleeman99
Default RE: heads
i live in canada and it cost about 2000 for after market haeds
Old Nov 19, 2006 | 08:06 PM
Indy's Avatar
Indy
Default RE: heads
Yeah man, I hear you... parts up here don't seem as cheap as they do in the Summit catalogue! LOL.
I got my Eddy RPM's for around $1400.00 + tax. They're the 2.02/1.60 valve ones. The heads are complete. I'm super happy with them.
I think I had a quote of around $750.00 - $800.00 to machine my D0OZ heads, install new stock sized valves (1.84/1.54), new valve guides ect... No porting in that price yet. No valve springs for my application in that price yet either! So you see, even if I spent that and the rest of the money needed to dress those heads, they would still be out performed by a pair of aftermarkets!
The most important thing to do is commit to a performance level, and stick to it! That way you can do it right and do it ONCE! If the stock chunks of iron are going to work for you, than go for it.
Here's a link to a site you may have already seen. I found it to be a helpful guideline. Check it out, and good luck. Let us know how you make out.
http://www.jason.fletcher.net/tech/combos/combos.htm
Indy
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
