351 Mustang
12.4:1 compression.
Old Nov 12, 2006 | 07:24 AM
Q8Notch's Avatar
Q8Notch
Default 12.4:1 compression.
my compression ratio is 12.4:1, is it possible running it on pump gas? 93 or 90 octane?
its a 408W.
Thanks in advance folks.
Old Nov 12, 2006 | 07:37 PM
92BOOSTED's Avatar
92BOOSTED
Default RE: 12.4:1 compression.
You can do it on 93 octane minimum but i would back the timing down just a bit. The problem is you would not get the benefits of the
cubes and compression because you decided to go with cheaper fuel. Horsepower will be down, but it will be safe..
BTW, if it is carbed then you might have to rejet it.
Ryan
Old Nov 14, 2006 | 12:31 PM
r.barn's Avatar
r.barn
you can always run water/meth injection to help
www.snowperformance.net ......... they make a N/A system too
Old Nov 18, 2006 | 10:38 AM
S351R13's Avatar
S351R13
With the timing retarded it will probably run a little on the warm side also.
Old Dec 20, 2006 | 06:05 AM
atomsk680's Avatar
atomsk680
retard the timing a bit OR get 93 octane and buy a whole lotta octane boost. easier and cheaper to Not get that high of CR
Old Dec 20, 2006 | 09:44 AM
Arrid Extra Dry's Avatar
Arrid Extra Dry
RACING FUEL AND ITS 7 BUCKS A GALLON AROUND HERE
Old Dec 20, 2006 | 12:32 PM
Shmeddie's Avatar
Shmeddie
ORIGINAL: Arrid Extra Dry
jesus where you at?
its not that bad in florida yet....[:'(]
canadiantofu
Aug 26, 2006 10:53 PM
jrrhd73must
May 5, 2005 12:39 PM
bobby
Oct 18, 2004 07:56 PM
blkgt50
Jul 20, 2004 10:41 PM
