Spark Plug Gap
Old May 4, 2005 | 06:18 PM
jrrhd73must's Avatar
jrrhd73must
Default Spark Plug Gap
Has any one seen any guides on this? I have what the stock plug gap should be for all years and engines, however I have a 351C running 11-1 compression. I just changed the spark plugs - I gapped to origianl - however I was thinking that it might be different due to the compression.
Old May 4, 2005 | 07:54 PM
69mach1377's Avatar
69mach1377
Default RE: Spark Plug Gap
Higher compression requires either smaller gaps or stronger sparks...
Old May 4, 2005 | 11:26 PM
69FECoupe's Avatar
69FECoupe
I second 69mach's sentiments. The higher the compression, the more energy it takes to jump the gap. If your ignition is stock, now may be a good time to upgrade it a bit.
Old May 5, 2005 | 07:09 AM
Soaring's Avatar
Soaring
I ♥ Acer
Welcome to the site. If you don't have the pertronix or MSD electronic ignition components, you might want to consider them.
Old May 5, 2005 | 11:05 AM
jrrhd73must
ORIGINAL: Soaring
Got Both....
I checked a high performance engine builder book last night and it said that the gap stays the same, but I want a colder plug. If you look at the Ford manuals for the standard 351C it calls out and Autolite BF42 however for the Boss 351C it calls out a BF32 and sometimes a AF42.
Old May 5, 2005 | 12:39 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you have the electronic ignition, you can leave the gap the same, or even open them up a bit, if you have the flame thrower coil as well.
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
lmurf60
Sep 24, 2015 10:07 PM
